Old 09-12-2007, 05:17 AM   #3916
Trader Rating: 16 (94%+)
Originally Posted by G2B Anthony View Post
Does anyone know how thick is the TC5 inner hinge pin?
The inner hinge pins are 3.0mm. After 3-months of racing, I have yet to bend one.
KSN
kn7671 is offline   Reply With Quote
Old 09-12-2007, 06:39 AM   #3917
JCB
JCB's Avatar
The car is very durable... I've been running it hard for the past 7 weeks with no issues.
JCB is offline   Reply With Quote
Old 09-12-2007, 12:21 PM   #3918
Send a message via MSN to TurboT
Has anyone had any issues with the rear hubs adding or subtracting toe? I built mine and the left side of my car ended up having almost positive toe when using the stock suggested 2 degree shims on both sides.
My solution until I get some new parts to try is that I'm running 3 degrees worth of shims on the left and 1 degree on the right. The result is very close to 1.5 degrees on both sides.
I'm also interested in aluminum rear hubs, mainly to try and keep both sides even. Molded parts suck.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 09-12-2007, 12:43 PM   #3919
robk's Avatar
Trader Rating: 22 (100%+)
I hope some company out there will come out with hubs, caster blocks and steering knuckles in AL. That would be sweet.
Old 09-12-2007, 01:53 PM   #3920
ooliganRC's Avatar
Send a message via MSN to ooliganRC
stock rear hubs? or .5 or 1 deg ones. I would suggest taking it all apart again and checking nothing is bent.
if your using the rear 0 deg hubs then you defo have an issue.
ooliganRC is offline   Reply With Quote
Old 09-12-2007, 01:55 PM   #3921
JuhoL's Avatar
Does the toe change if you flip the hubs from side to side? Are they new hubs? I havent seen any new hubs that arent right so far. Sometimes you bend them in big crashes though. The holes are molded and not drilled so they should be pretty accurate.
Also make sure the arm mounts are not backwards?
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 09-12-2007, 03:14 PM   #3922
Send a message via MSN to Bigger Brother
Hi everyone
I'm very very close to getting a TC5, basically I want to know what option parts are worth having, and what spares its worth keeping a few of (guessing wishbones, hubs etc?... anything else?)
Also, since I've only had cars with english size screws, what allen and nut drivers will I need?
Oli, UK
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 09-12-2007, 03:36 PM   #3923
i would definitly get some extras of the plastic part of the shock caps
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 09-12-2007, 04:12 PM   #3924
hanzo3's Avatar
Trader Rating: 55 (100%+)
For metric, you need 1.5mm and 2.0mm hex drivers.
hanzo3 is offline   Reply With Quote
Old 09-12-2007, 05:00 PM   #3925
Maybell's Avatar
Originally Posted by Bigger Brother View Post
Hi everyone
Oli, UK
also get a 2mm ball driver when you can.....for the inner hinge-pin mounts..
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 09-12-2007, 05:19 PM   #3926
Hi everyone
Oli, UK
Spare Parts
I highly recommend you get the following spare parts if you are going to be racing:
Caster Blocks - get 3+ sets, each side is specific - 4-degree = AE Part# 31212
Steering Blocks - get 3+ sets, each side is specific
Rear Hubs - get 2+ sets, 0-degree will work on either side
Front and Rear Suspension Arms - 1 set each - AE Part # 31205 & 31206
Silver Ball Studs 8mm Long - AE Part # 31284
Ball Stud Spacers - they get lost - AE Part # 31286
Diff Outdrives - 1+ sets - AE Part # 31167
Bearings - 6x10x4mm wheel bearings - hitting the boards = toasted bearings
Arm Mount Nuts - I have had two of these pull apart - AE Part # 31197
Arm Mounts - they will break, and extras are not included - AE Part # 31195
Wheel Base Shims - If you break, this might get lost - AE Part # 31200
Hinge Pins - Inner and Outer - AE Part # 31221 & 31222
Extra Screws - RC Screws will give you lots of extras when lost or bent
Tools
The following tools are recommended:
2mm Ball Hex Driver - a MUST HAVE to service the suspension arms
2mm Hex Driver - high quality non-ball with replaceable tip - main tool 90% of screws
7mm Nut Driver - for the wheel nuts
KSN
Old 09-12-2007, 06:25 PM   #3927
Trader Rating: 14 (100%+)
Heads up on shock caps:
I thought I bought a shock cap set, in the manual, they listed it as 31120 next to the picture of the cap where you assemble the shocks. I got the package today and it is only the shock rebuild kit, no shock caps. I dug a little deeper and shock caps 31121, not 31120 as listed.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-12-2007, 07:23 PM   #3928
Heck, if we want to go there, the AE TC5 manual states the wheel bearings are 6x10x3mm bearings, but they are actually 6x10x4mm.
I like the TC5, but I would love to work for AE and go through each new kit and manual and QA/proof/correct things, add building tips along the way, and explain what each adjustments effects will have on the kit during the building process, not at the end. This is something the TC5 only touches on, and all of it is at the end of the build.
KSN
Old 09-12-2007, 07:37 PM   #3929
Trader Rating: 71 (100%+)
I heard Team Tamale might be making these.... You may want to check with him. If he is not currently making them it might be something he would be interested in....
RBLove is offline   Reply With Quote
Old 09-12-2007, 07:48 PM   #3930
mo
mo's Avatar
I just measured a front wheel bearing on my TC5 and it is 3mm thick. The manual is correct.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
