Old 09-08-2007, 12:14 PM   #3901
Verndog's Avatar
Trader Rating: 16 (100%+)
Default Question on one way.
Got the TC5 one way together last night. There really is nothing to tighten other then the pulley to the diff housing. The outdrives "float" and are
only held by the position by the end of the CVD's, and the one way bearings
are pressed in permenantly into the housing. Guess I have to replace that whole assy. when bearing goes. The one way came with no instructions and
I wanted to check this is correct. Also, how often do you repack them with
the supplied silicone grease, and how long should I expect them to last?
My original rear diff (1/2 off tight) was still in good shape, but I rebuilt anyway, and the front (1/8 off) was just starting to bind...they both had
60+ runs on them. I'm happy with the diff design.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-08-2007, 01:34 PM   #3902
JuhoL's Avatar
You only need a little bit of silicone grease on the axles, no need to fill the whole bearing with it You should be able to get a LOT of runs from the oneway. Just keep checking the outdrives for wear. If the axle starts to look really polished its a good idea to replace them. They will start to slip if they are worn out. I've been using the outdrives for atleast 50-100 runs, depending on motor, conditions etc. The bearing should last much longer than that if it's not abused too bad.
I think you can get the outdrives and bearing separately too.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 09-08-2007, 05:40 PM   #3903
Verndog's Avatar
Too late. Already filled it. I dont think it will hurt anything, but I wont waste so much next time. So, you think the outdrives are the first wear item I should "stock" rather then the housing/bearing assy? The outdrives are made of steel and I figured would last...but I'm sure the bearings are much harder material. Yes...you can buy seperate, I've seen them "on auction" already.
---Team Hoarders---
Old 09-09-2007, 08:48 AM   #3904
Verndog no need to stock them it will be quite awhile before you will need to replace the 1-ways or the outdrive.
Difuser is offline   Reply With Quote
Old 09-09-2007, 02:24 PM   #3905
Jea3's Avatar
does anyone make an aluminum rear hub for this thing yet? Like a Serpent, or Corally?
I know, stay off the boards.. I went from racing Nitro Expert to Electric Mod, but also took a year off. This car is sick, but the day before the race, I went out to test out the new Novak 3.5 with Orion 4800 Li-Po. The Li-Po came loose, and hit the belt in the straight, and I brushed the wall as the tires locked up. Broke the Left Rear Hub. No one had any, so I got another kit, just for the hubs. On race day, at the start of the first qualifier, I glitched, and brushed the same dang wall, in the same area, and broke the same hub. Very light brush too, but still my fault.
150 ft straights, ashphalt.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 09-09-2007, 02:34 PM   #3906
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
that sucks tell pete to stock some parts!!!
Old 09-09-2007, 03:50 PM   #3907
ooliganRC's Avatar
Send a message via MSN to ooliganRC
good thing they are 0 deg. at least right and left are the same so you have a spare :P
ooliganRC is offline   Reply With Quote
Old 09-09-2007, 10:17 PM   #3908
Jea3's Avatar
I called Superior, nothing, and I manage the new Hobbytown RC department, and we didn't have them, and I tried PNP, nope. I went 2 work right after I left the track, and ordered 6 of every degree from AE.
Old 09-10-2007, 01:59 PM   #3909
nocif13's Avatar
Send a message via MSN to nocif13
http://theassoboyz.blogspot.com
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Old 09-10-2007, 11:31 PM   #3910
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
I am looking for good setups for foam carpet for stock. With IIC coming up and no local carpet track to practice on it is pretty much impossible to work on one right now.
Corey
RoachRacing is offline   Reply With Quote
Old 09-11-2007, 06:13 AM   #3911
Trader Rating: 16 (94%+)
Corey
I really like the Craig Drescher setup from Snowbirds 2007 for Carpet Foam. Here is a direct link to the PDF from Associated's website for the setup. The car is easy to drive, not twitchy, and has good rear traction.
http://www.teamassociated.com/racerh...wbird_2007.pdf
KSN
kn7671 is offline   Reply With Quote
Old 09-11-2007, 12:26 PM   #3912
nocif13's Avatar
spool tc5 news ,for tc5, make home and indestructible, more solid than spOOL ae
http://blogsperso.orange.fr/web/jsp/...?blogID=127906
This must be the best spool in the market. Very good quality, excellent finish, very light. It gives a lot of steering and helps for a very smooth transmission. The replacable derlin cups are also excellent.
Xluis
06/02/07
Only a word, AWESOME กกก , 2 spools, 2 finalist A in Spanish Cup of Champions. A piece of art. Good job Patrick.
Old 09-11-2007, 12:29 PM   #3913
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I just made a spool from a header card. I worked great all day last week running Mod. Just remove the diff balls and rings, cut a Losi or X-Ray header card in the shape of a diff ring (w/o the d part), and super glue it to the outdrive. The Crank it down.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 09-11-2007, 05:47 PM   #3914
Trader Rating: 71 (100%+)
A good friend (junior) of mine is looking for a front belt (Yokomo or Bomber). If any of you have one for sale hit me on PM.
RBLove is offline   Reply With Quote
Old 09-12-2007, 03:11 AM   #3915
Does anyone know how thick is the TC5 inner hinge pin?
G2B Anthony is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
