Old 08-29-2007, 09:11 PM   #3811
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Originally Posted by G2B Anthony View Post
what's your set up? or just the instruction manual set up?
I was afraid someone would ask that !
I was handed the car at the track, I put a set of CS27s on it, a CO27 T Bang stock motor in it, charged my cells and raced.
I didn't touch the setup all night.
So, I couldn't say what it was, but I can say that the car worked great, so it is possible to dial in a setup that worked for me on that surface.
The thing that impressed me the most though was right from putting the car on the track the first lap I knew it was going to be good.
stulec52 is offline   Reply With Quote
Old 08-29-2007, 10:28 PM   #3812
Send a message via MSN to Fabian K
Just to share my setup for everyone , the car was awesome I made TQ and won the first race for the TC5 here in Brazil ;
LOW TO MEDIUM TRACTION ASPHALT OPEN LARGE TRACK - WITH HAND OUT TIRES
RIDE HEIGHT 5,5 REAR 5,0 FRONT
CAMBER 1,5 ALL
CASTER 4 DEG
TOE IN REAR 2,5 TOTAL (REAR HUB 0,5)
FRONT TOE 0
HEX SPACING - NO
WHEEL BASE REAR 1MM FRONT 2 MM
STEERING LINK 1 B
BUMB STEER - NO
SPOOL ON FRONT
REAR DIFF 1/8 OUT
CAM HOLDER A FRONT MID HIGH - REAR MID HIGH
SHOCK OIL 30 WT PISTON # 1 ALL AROUND
REBOUND - NO
FRONT SPRING ASSOC BLUE
REAR SPRING ASSOC SILVER
SHOCK POSITION FRONT 3 B
SHOCK POSITION REAR 3 B
CAMBER LINK REAR 3 A WITH 2MM SHIMS
CAMBER LINK FRONT 3
REAR SUSPENSION MOUNTS
FWD ARM MOUNT 2 A
NO SHIMS
RWD ARM MOUNTS 2 A
WITH 2 DEG SHIMS
FRONT SUSPENSION MOUNTS
FWD ARM MOUNT 1 A
NO SHIMS
RWD ARM MOUNTS 2 A
NO SHIMS
ANTI ROLL BAR 1,25 MM
JUST ON REAR
NO ANTI ROLL BAR ON FRONT
CHASSIS AND TOP PLATE ITF (without o-rings/all screws tight on top deck)
MOTOR X11 3.5
GEAR 87/21
SPEED SPHERE TC - VALUES 2 - 4 - 0 - 0
BODY STRATUS 3.0
5 CELLS RWD - ON BACK POSITION
GREAT CAR - Congratulations TEAM ASSOCIATED
Fabian Kaloustian
TEAM ASSOCIATED - REEDY - LRP - JACO
Fabian K is offline   Reply With Quote
Old 08-30-2007, 12:52 AM   #3813
I have changed the front drive belt to BD one, result is very smooth and very flexible for the belt tension choice. Try Try
Besides, does anyone tried use 4 O-ring to the upper deck rear screw position? Any different.
G2B Anthony is offline   Reply With Quote
Old 08-30-2007, 02:04 AM   #3814
zacabrandy's Avatar
I dont understand why everyone is changing the belts on this car? The belts I recieved with it are fantastic, super strong, smooth and have plenty of flex and adjustment.
I run mod, 19T, and find them to be just fine, am I missing something here?
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 08-30-2007, 04:03 AM   #3815
ooliganRC's Avatar
Send a message via MSN to ooliganRC
Originally Posted by DOTMAN View Post
I've had one for almost two-months...just haven't built it. Been waiting for parts and the spool and the one-way. I just got the ITF chassis. Now that Tamiya season is over...gonna start building it. I should have it on the track by next weekend. Maybe someday, there will even be a spool for it
titanium racing make one.
also precision rc has one way units on there site
ooliganRC is offline   Reply With Quote
Old 08-30-2007, 08:45 AM   #3816
Trader Rating: 16 (94%+)
Cheers
Aaron
With a mod or 19T motor, the belt should be fine. The stock belt is slightly rigid and does not stretch much. In stock racing I can see where a looser, slightly more pliable belt could be beneficial.
I've been running my TC5 for about 8-weeks now, 13.5 BL, and the belts don't seem to have loosened up much at all.
KSN
kn7671 is offline   Reply With Quote
Old 08-30-2007, 09:25 AM   #3817
tcfree's Avatar
The belts will not loosen up if any @ all, the yokomo/bomber 1 is made from a diffrent material so it flex's more, and as for class of racing either it be 27t 19t or a mod with lipo u still want a free/smooth drive train, the belt change does make a diffrence
Ste.
tcfree is offline   Reply With Quote
Old 08-30-2007, 09:32 AM   #3818
i run all 4 screws with o-rings on the back and i do think the car flexes quite a bit more with four rather than 2 also i did it because my car was tweaked bad and when i put all 4 orings on there and put it back on the tweak board it really helped alot. this is with the ITF chassis and top deck.
also do you know what the part # was for the belt that you got? i ordered one just hope its the right one its for the BD car
anyone or everyone else, what is everyone gearing their car? 48p or 64p? stock, 19t and mod?? rubber tires? i ran a 38/100 on a 10.5 BL on carpet with rubber tires but my next race is at the kissimee track where the worlds were in 2004 i plan on running either 19t or mod so any advice would be much appreciated as far as gearing goes
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 08-30-2007, 09:42 AM   #3819
tcfree's Avatar
Team Bomber (#TB20022) Front Drive Belt For BD
or
BD FRONT DRIVE BELT BD516L.
The bomber 1 is better but std yokomo belt is better than tc5 kit belt
Old 08-30-2007, 10:13 AM   #3820
Verndog's Avatar
Trader Rating: 16 (100%+)
Cheers
Aaron
Couldn't agree more. I expected to have some possible issues (from reading these posts) with mine and after 50+ runs the belts are working flawlessly. A little tight to start on rear but that loosened the first 10 runs and is staying put now. I wont be switching belts without some other reason.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 08-30-2007, 11:54 AM   #3821
tcfree's Avatar
hi, Just i found the std belts 2 be very tight even on the slack settings on the cam, after 50+ run's i shud think it wud loosen up, aslong as it's working for u thats good
Dunno who said about my power cap being in a bad place??
This any better?
ste
Old 08-30-2007, 12:24 PM   #3822
RAP66's Avatar
Same here... my belts seem perfectly fine
RAP66 is offline   Reply With Quote
Old 08-30-2007, 01:06 PM   #3823
KING COOPA's Avatar
are you guys changing the rear also. my belts seem to be find but idk. also where are you guys getting the white spurs?
KING COOPA is offline   Reply With Quote
Old 08-30-2007, 01:22 PM   #3824
dont us wrong guys the stock belts are fine. they hold up well. the only complaint people are having is that they are just a little to tight. in my case my car probably has 15+ runs on it now and the belt even in its loosest position is still tight enough to tweak the car. i felt a few other cars at the track and theirs were waay looser than mine so i figured personally that i would try something to fix it. Associated already has plans for another low-friction belt to come out at some point because the part # is already in the part catalog that comes with the kit.
Leon McIntosh
Old 08-30-2007, 01:37 PM   #3825
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Yeah my belts are super tight on my car as well. I tried to run my rear diff in the lowest possible position and the rear belt was so tight it was tweaking my car. Has anyone else been able to run the rear diff utra low and the belt feel fine tension wise? Has anyone tired to take every other tooth off the belts to soften them up some? I might just try a BD front belt and then wait for the Associated low friction belts but thats not helping me now. What have some of the guys with belt problems tired other then soakin the belt in Oil?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
