Old 08-27-2007, 04:21 AM   #3766
highwayman's Avatar
Originally Posted by zacabrandy View Post
Can someone please tell me where i can get spur gears that suit the TC5.
Im looking for 88 thru 90 49P. I tried the Xenon ones but it means I can only use 2 of the screws and Im not sure if that would be good for modified.
Cheers
Aaron
speedmind ; X-ray and kimbrough will fit the TC5
highwayman is offline   Reply With Quote
Old 08-27-2007, 09:27 AM   #3767
JCB
JCB's Avatar
I'm running PRS spurs with no issues...
JCB is offline   Reply With Quote
Old 08-27-2007, 11:39 AM   #3768
Trader Rating: 76 (100%+)
Does anyone have any set-ups for high grip asphalt.
MUDVAYNE is offline   Reply With Quote
Old 08-27-2007, 11:39 AM   #3769
Does anyone have any set-ups for high grip asphalt?
Old 08-27-2007, 12:03 PM   #3770
smyka's Avatar
Send a message via AIM to smyka
the one thing i have noticed with the the car is you need to break the belts in if not it seems to bind the drive train and makes the car very unperdictible i had my belts as loose as they would go and it was still to tight so i let them sit in marvel mistery oil over night and the soften up a ton i put them back on my car and what a difference the drive train was super smooth and free ..
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 08-27-2007, 12:20 PM   #3771
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
ditto.
I'm running a 112/34 (6.59) on a freshly cut CO27 yet I dont seem to have the punch I would like... any suggestions?
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 08-27-2007, 01:50 PM   #3772
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by K_Spec_RC View Post
ditto.
Larger spur. Run the biggest spur you can to make the proper ratio. A bigger spur will always have more rip. I ran the car for the first time this weekend, and was running a 35/114 with adjustment room to spare (too much room). I think you will be able to get away with a 120, maybe a 124, but I am not positive.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-27-2007, 03:14 PM   #3773
Trader Rating: 16 (94%+)
ditto.
I think you need to be closer to 7.0 with a CO27. What tire are you running, and what diameter are they?
With a 13.5 BL motor and foam 56-58mm tires, I run a 4.7 to 5.0 fdr.
KSN
kn7671 is offline   Reply With Quote
Old 08-27-2007, 04:59 PM   #3774
Weasely's Avatar
Default binding steering...
I'm nearing the end of building my TC5, which coincidentally happens to be my first kit type tourer in a longer list of off-road pursuits.. I've gotten to clipping on all the turnbuckles, having gone back to make sure everything is as free and smooth as can possibly be - the belt tension makes the drive train a little sticky, but i entirley expected that after reading through this thread a bit. The belts are on their loosest settings, respectivley.
However, thats not the problem - Now that ive clipped on the camber turnbuckle the steering is binding in a terrible way! Its fairly stiff to turn the steering mechanism by hand. Clearly its just the ball cup thats gripping onto its little ball-doodad that turns with the steering knuckle, but what can be done to free this up a little bit? Or will it even really be an issue? Smooth free steering seems to me like it would be a definate plus... Ive squeezed a bit of grease into the ball cup and replaced it, but its really not helped much.
I'm thinking i'll steal a metal geared servo from my nitro buggy :/
Weasely is offline   Reply With Quote
Old 08-27-2007, 05:24 PM   #3775
Trader Rating: 21 (100%+)
Squeeze the ball cup on the ball with a pair of pliers.squeeze along the lenght of it.Usually frees it up.
lotus1 is offline   Reply With Quote
Old 08-27-2007, 05:43 PM   #3776
RBLove's Avatar
Trader Rating: 72 (100%+)
Mark,
How have you been dude? Are you going to the Classic this year?
Do you do this on all of your belt cars? Are you currently running the TC5?
Here is a link about the oil he is referring:
http://www.marvelmysteryoil.com/main.taf?p=1
RBLove is offline   Reply With Quote
Old 08-27-2007, 06:30 PM   #3777
Weasely's Avatar
hey, thanks I'll try that when i get home.
I also noticed, when turning the drive belt, that the spur gear looks like it wobbles by about 1mm.. I've pulled it out a few times, and tried re-screwing it onto the smaller pulleys, but its just the same, like theres a bit of distortion in it. Ive tried with the screws both lose, and tight.. maybe it just came this way?
I hope it wont be a problem :/
Old 08-27-2007, 07:03 PM   #3778
Change to the Yokomo BD front belt , it is longer and softer than the original one. Solve all the problem.
G2B Anthony is offline   Reply With Quote
Old 08-27-2007, 07:09 PM   #3779
RCpurplecow's Avatar
quick question, the tc5 is my first belt car and I was wondering if there is a difference between the two types of plastic pieces that hold the differentials. I'm really confused because they look the same...? I got eight of them with my kit. Which ones do I use?
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 08-27-2007, 07:20 PM   #3780
Weasely's Avatar
There are two sets of four from what i saw - one set without holes in the side, and one set with.
The manual shows putting in the ones without holes in the side. My rear belt was WAY too tight, so i tried the ones with holes. It seemed to make it a little bit looser. So thats what i've got in there now. :x
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
