Old 08-24-2007, 04:20 PM   #3751
tcfree's Avatar
Originally Posted by punkracer24 View Post
so i could use some help from some on-road regulars. i just got my tc5 together last night and my questions are
1) what should you set the belt tension to for stock and 19t rubber tire racing?
-i built it with i beleive 5 in the front and 2 in the rear i think
2) what do you gear a stock and 19t with the 87t spur? or any other suggested gearings?? also wut about the brushless 13.5s and 10.5s?
any suggestions would be much appreciated. ive been running 1/8th offroad for the last two years and cant remember a thing about the details of onroad racing
leon mcintosh
Hi, for the belts u wanna run them very loose/slack 'std out the box belt settings is very tight/2 tight in my view'
As for gearing totaly depends what type/size of track u are gonna be running on but start wiv about 8. 2 times 87 devide by 22 = 7.9, so i wud try a 22 tooth pinion to start. u will tell stright away if u need 2 gear up or down on the track just by driving a lap or 2 !!
ste e.
tcfree is offline   Reply With Quote
Old 08-25-2007, 08:28 PM   #3752
JCB
JCB's Avatar
Hey guys,
I'm just curious if there are any updated belts for the tc5 other than the ones that came with the kit? I just got in from the track and someone mentioned to me that there a new belts out for this car... please let me know.
thanks,
JCB is offline   Reply With Quote
Old 08-26-2007, 01:38 AM   #3753
bxpitbull's Avatar
One of my dudes just ordered the TC5, velineon brushless system and 8000 mah lipo. I told him this was overkill AND the 8000mah might not fit. This dude has been killing folks with 1/8th scale nitro and this is his first attempt at electric. What could have done to get:
excellent run time
excellent speed
cells that fit in the TC5
Thanks.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 08-26-2007, 03:02 AM   #3754
zacabrandy's Avatar
Ran the car for the first time today, 4.5, rubber. I have to say very impressed although I could not stop it from oversteering into the corners, as soon as i got off the throttle and went to turn in it just hooked madly.
What I need is some good base set ups.
1 for a rough, very low grip concrete track
2 Medium grip asphalt track
All outdoor, rubber, modified.
Anyone have any good one please let me know.
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 08-26-2007, 04:18 AM   #3755
zacabrandy's Avatar
Can someone please tell me where i can get spur gears that suit the TC5.
Im looking for 88 thru 90 49P.
Cheers
Aaron
Old 08-26-2007, 04:27 AM   #3756
Got a try to answer for med grip asphalt track (just copy & paste the last link!)
27/05/2007
Ryan Cavalieri - Bob Stellflue - Brent Thielke - Tommi Torikka - Kyle Skidmore - EA
Event: Reedy Race
Traction: Medium
Team Associated TC5 - Brent Thielke - Asphalt Rubber Tyre Setup
There is some more here!
Arn0 is offline   Reply With Quote
Old 08-26-2007, 03:26 PM   #3757
Send a message via MSN to TurboT
I just built my TC5 and I have to say that it went together pretty smooth! I've been driving Xrays and an RDX for awhile now and this new car is definitely in the running for car of the year! The only issue I had was with the outer hinge pins being a tad too sticky (read: damn tight until I dremmeled them) and one of my rear uprights was too tight in the arm so that it wouldn't pivot past a certain angle, so I dremmeled that too.
Other than that, awesome! I can't wait to run it! I'm still waiting for my one-way, but other than that I'll be good to go!
I'm pumped!
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 08-26-2007, 03:57 PM   #3758
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I'm pumped!
Instead of dremeling stuff...... polish the hinge pins with wax nd a micro fibre cloth.... its amazing to see the difference in how smooth and free everything is. All the black coating will come off and the pins will be a chrome finish, and work very nicely
wallstreet is offline   Reply With Quote
Old 08-26-2007, 04:03 PM   #3759
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Interesting. What kind of wax?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 08-26-2007, 04:11 PM   #3760
wallstreet's Avatar
Mothers. It comes in a white metal jar... can get it at any hardware store... When i get home ill give you the exact name.
Old 08-26-2007, 06:29 PM   #3761
Trader Rating: 14 (100%+)
The hingepins in my kit were smooth, no prep necessary. I did notice that they were coated in oil to prevent rusting i assume. I took some brake cleaner and cleaned the pins.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 08-26-2007, 06:40 PM   #3762
wallstreet's Avatar
they are all smooth, i think he was saying the arms didnt move freely on the pins.. Thunder if you polished them and put them back on the car with the shocks off you will see there is a huge difference.
Old 08-26-2007, 07:08 PM   #3763
Yup, I did notice that the arms were "sticky" when I mounted the arms. This is mainly due to the the arm mounts not being perfectly aligned. There was a tip posted a couple pages back on how to fix it. I'll try polishing tho, wouldnt hurt anything.
This is how I did it. When you attach the arm mounts and arms to the bulkhead, tighten so its just snug. Take the handle of your hex drive and tap on the ball stud that the shock attaches to. It kinda "sets" the arm mounts so that theyre in line better. Its pretty useful when you start playing around with squat/dive stuff when the hinge pin is angled.
Hopefully ill make it back to harbor sometime. Ive been pretty busy running nitro
Old 08-27-2007, 12:53 AM   #3764
zacabrandy's Avatar
Im looking for 88 thru 90 49P. I tried the Xenon ones but it means I can only use 2 of the screws and Im not sure if that would be good for modified.
Cheers
Aaron
Old 08-27-2007, 04:06 AM   #3765
Cheers
Aaron
Just use Kimbrough spurs, I'm using them myself... For a good setup for a rough low grip track, check my setup at rickthomson.tk and use the HFCC The Hague setup
Rick Thomson is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
