Old 08-02-2007, 05:53 PM   #3496
dbmartin's Avatar
Originally Posted by Obsidian View Post
Is there a P-dub bumper available for the TC5?
I spoke with paul back in june and he stated he was going to make one, but i haven't seen him since then.
you can send a pm to "pw" and he will let you know if he has one
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 08-02-2007, 06:01 PM   #3497
dbmartin's Avatar
tower is now showing late august for the alum diff and spool.
this is the third month in a row it has changed eta's
I have had these on order for almost 2 months now, is there a more definitive eta on when these will ship.
Old 08-02-2007, 07:16 PM   #3498
corallyman's Avatar
Trader Rating: 97 (100%+)
I just checked and it says early august for both items.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-02-2007, 07:35 PM   #3499
HarshGuy's Avatar
Originally Posted by STLNLST View Post
Yes I did. Virgin run this weekend on the car.
And like a virgin ...it's probably gonna hurt j/k good luck this weekend, we'll be doing confined dives this weekend ...this diving thing is looking more and more fun the more we learn about it ...hmmm ...new hobby
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-02-2007, 11:18 PM   #3500
highwayman's Avatar
Originally Posted by Donn View Post
Just a heads up, for you guys going to run the Aluminum Out drives in the TC5, you will also need the CVA Blades #31238, cost is $3.99 for 8 and you should keep and eye on them at they are wearing part and have to be replaced every so often.
how about for the spool? would it also require blades? thanks....
highwayman is offline   Reply With Quote
Old 08-03-2007, 02:12 AM   #3501
corallyman's Avatar
Default Euro's TC
51,
Sent you a PM, I hope that works for you. It doesn't appear to be live updates, but it does refresh after the run is complete.
Steve
Old 08-03-2007, 06:59 AM   #3502
Trader Rating: 14 (100%+)
I'm currently rebuilding a TC5 that I bought used. When attaching the arms, the arms arent falling freely. Im using all the same arm mount blocks (2 dots). Could it be my wheelbase spacers are a little on the thick side?
Also, on the aluminum bulkheads, on aluminum bulkheads, was the middle chassis mount hole tapped after anodizing? Theyre all silver on my bulkheads and one of them has a really tight fit.
This is my first electric TC (been racing nitro TC's for years) and im happy with the quality and on par with my Mugen. Parts count is way low compared to the nitro TC too, I couldnt believe i took the entire car apart in about 15 min.
So whens the NTC5 coming out
thunderbt3 is offline   Reply With Quote
Old 08-03-2007, 09:06 AM   #3503
Maybell's Avatar
Now thats some funny stuff right there!!!
Summer Sizz next weekend...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 08-03-2007, 11:48 AM   #3504
51
51's Avatar
It could be helpful if you could take and post some pics of the bulkheads...they shouldn't be tapped at all. The screw goes through the bulkhead and threads in to the blue nut that holds on the arm mount.
As for the tight arm...i know it sounds strange, but try tapping the arm to "set" it in to place...I usually hit right on the ballstud where the shock attaches with my wrench. If it's still tight, try sanding the arm mount spacers with a nail file. Remember, there should only be 1x1mm and 1x2mm shim spacing the arms front to back.
Were you able to get the manual with the used kit?
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 08-03-2007, 01:11 PM   #3505
Thanks for the tip and I did recieve a manual with the kit,
I think you're thinking about the arm mount holes being tapped. Those are completely fine. The screw holes im talking about are the 3 holes in the bulkhead that attach the bulkhead to the chassis.
The hole in the middle of all 4 bulkheads are silver instead of blue and seem like they've been tapped after anodizing. One of the holes seems really tight but after inspection, it doesnt look crossthreaded. Just wondering if it just needs to be cleaned out a little bit.
Old 08-03-2007, 01:45 PM   #3506
STARSCREAM's Avatar
one-way just came in...
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 08-03-2007, 03:47 PM   #3507
nutsisneat's Avatar
I have a problem with one of my dampers. Just one, the others are fine.
It is leaking a lot. After a 5 minute run there is a drop of oil below the piston rod
How can i rebuild the damper, how can i get out this cartridge without destroying it? Has anyone already maintained his dampers?
Other question: if it won't work, would TRF dampers maybe fit?
Thanks for replies...
nutsisneat is offline   Reply With Quote
Old 08-03-2007, 04:43 PM   #3508
STLNLST's Avatar
Trader Rating: 17 (100%+)
I get to run my TC5 tomorrow.....
51- Thanks for all the info at the nats. Tomorrow I will try to be the black Ryan C......ha ha ha ha ha
STLNLST is offline   Reply With Quote
Old 08-03-2007, 04:45 PM   #3509
51
51's Avatar
Got'cha. Most likely the owner before you put some loctite or superglue or something else in there to help keep the screw in. I would suggest getting a new screw and with the bulkhead off the car, threading the screw in to clean out the threads as much as possible. Then motor spray out the hole to fully clean out the debris.
Old 08-03-2007, 04:49 PM   #3510
51
51's Avatar
Probably the o-ring was cut during the install. Use the shock tool to press the slug out from the bottom paying special attention to where you are pressing. Make sure you don't scar the inside where the shaft rubs. The process sounds complicated, but once you've done it a few times it gets easier. Is there someone at your track who has used the VCS2 system before?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
