Old 07-15-2007, 04:26 PM   #3346
kdub's Avatar
Some more diff tips to add:
I tend to set mine at only 1/8 turn out to start and then maybe loosen it a little after I know it is seated from a run on the track.
Try a bit of blue loctite on the threads of the thrust screw as some extra insurance to keep the screw from loosening.
I ran the same diff all through the Reedy Race and for 4 additional club race days before I finally rebuilt it. Same parts, just new outdrives...clean and re-lube and it feels great again.
kdub is offline   Reply With Quote
Old 07-15-2007, 04:39 PM   #3347
thachowman's Avatar
Trader Rating: 28 (100%+)
Originally Posted by zacabrandy View Post
How are you guy's finding this car on Asphalt with rubber tyres. Also are you experiencing any high wear items that would be good to keep stock of.
Also what weight shock oils are those who run in modified using, on apshalt with rubber tyres.
Cheers
Aaron
I ran my TC5 all day yesterday with a 3.5 on Take off's with virtually no tyre wear, they only just look scuffed in now, as for high wear items , Diff out drives, and a few of them, we went through three diffs yesterday between me and a mate , Jeff can get them at Trackside RC cheap too, As for shock oil I was running 40wt and had no problems, I just had to learn to drive the 3.5, Try Leonards setup for the Sunny coast track it is a real good starting point, I ran a different setup for my first 2 runs and the car was poo, pushing, taily, no turn in, then changed heaps to get it to Leonards setup and it was a completely different car..
Cheers
Andrew "Chow" Clough
_____________________________________________
Fraser Coast RC Car Club/FCRCCC :President
Yokomo - Futaba - LRP - Paint Made Special - Muchmore
thachowman is offline   Reply With Quote
Old 07-15-2007, 04:43 PM   #3348
thachowman's Avatar
Originally Posted by DirtyDog3375 View Post
Just a note to all that are having issues with diff meltdowns:
the standard diffs work perfectly fine with low wind b/l motors (3.5t and 4.5t) as long as you take care when building the diffs.
1. make sure the diff plates are cleaned with motor spray
2. place 4 small blobs (equally spaced) of silicone grease on the outdrive - d-ring area
3. make sure the diff plate is facing the correct way (sharp edge towards the outdrive -facing down away from the pulley)
4. build diff as per instructions (diff spring precompressed/diff nut securely held in place)
5. make sure the diff is tightened properly
Hope this helps you guys out.
-Leonard.
After Me munching a diff and my mate next to me doing one , Leonard gave us this hand piece of info,and I rebuilt mine at the track, and had no problems for the rest of the day, Thanks Leonard
Cheers
Old 07-15-2007, 06:03 PM   #3349
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hi Andrew,
No probs. Glad I could help out. Keep up the good work in mod.
- Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 07-15-2007, 09:53 PM   #3350
Trader Rating: 23 (100%+)
Good to see that Sean Cochran won the ROAR paved on road stock class today with the TC5! Nice job Sean! I believe there were 3 TC5's in the Mod A also.
SteveL is offline   Reply With Quote
Old 07-16-2007, 04:21 AM   #3351
B4Bandit's Avatar
Yeah! That's fantastic. Well done Sean
B4Bandit is offline   Reply With Quote
Old 07-16-2007, 05:33 PM   #3352
Maybell's Avatar
All the TC5s looked great going around the track at SIR!
...and Sean drove great...he can really wheel that thing!
cant wait till the Sizzler up here in Washington!
gotta try that 5 cell mod...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 07-16-2007, 08:14 PM   #3353
Verndog's Avatar
Trader Rating: 16 (100%+)
I'll second that! I got to watch some great racing Sat. and Sun. and meet Brent, Kyle, and Kevin. Got some tips and from Brent and Kyle and witnessed first hand what these cars are capable of doing on a asphalt track..WOW . Brent said he would post the setup sheets for our track...I'll be watching for those, also would like to see the final results for Team AE when you get a chance... had to leave before the day ended.
Great group of guys and great car for anyone thinking of a purchase...you wont be disappointed! Keep up the good work team.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 07-17-2007, 12:00 PM   #3354
yodace's Avatar
R/C Tech Charter Subscriber
Was wondering if u guys could help. Whats the final drive of a TC3 geared at spur78 pinion 19?
Also any thoughts on where i can pick up a fan for the motor?
yodace is offline   Reply With Quote
Old 07-17-2007, 12:10 PM   #3355
Internal is 2.5 so 78 * 2.5 / 19 = 10.26
DOTMAN is offline   Reply With Quote
Old 07-17-2007, 12:32 PM   #3356
overflow's Avatar
internal is 2.0 on the TC5
overflow is offline   Reply With Quote
Old 07-17-2007, 12:44 PM   #3357
He posted TC3...maybe he meant TC5
Old 07-17-2007, 03:13 PM   #3358
nutsisneat's Avatar
Default Loosing grip while using Spool
I melted my diff, due to lack of spares (like anyone else, i think), i had to build a spool.
With two diffs the car was always superb, but with the spool in front, i always lost rear grip while entering corners off-power. Is that something others have also recognized? I always thought that a spool will reduce front grip overall. BTW i raced on high bite carpet with rubber tires...
I took away rear anti-rollbar, used softer rear springs. Car was a bit better, but slower and more difficult to drive than before with my two diffs.
Has somebody an idea what i could do to bypass the time without the
alum.-diffs?
Thanks for your help guys...
nutsisneat is offline   Reply With Quote
Old 07-17-2007, 03:29 PM   #3359
I haven't had as much trouble getting spares as I did with my Xray. Things will get better.
There's been a lot of good advice here about how to build the diffs without burning them up. I'd start there if you like the feel of the front diff. You're running on carpet so the front diff may be the way to go.
If you want to run the spool, and it's rotating too much going in, try adding some rear camber. A little less up travel in the rear (higher droop gage number) may also help.
Unregistered is offline   Reply With Quote
Old 07-17-2007, 06:20 PM   #3360
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
you can also try some anti-squat in the rear. You should get more on power steering and less off power steering. I like this option better than using droop as it seems to isolate front to rear weight transfer from left to right roll, which you want with rubbers on carpet. I have used this on a T2 and an Mi3 on low low low bite carpet. I responded since we were in the same boat with the Mi3 as it came with a spool and we had to wait for the diff. Even with the diff we like it as I said we have low traction carpet. Really smoothes the rear of the car down off power. your results may vary
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
