Old 07-03-2007, 09:40 AM   #3256
kdub's Avatar
If you look on the setup sheet, the tension number depends on whether the bearing inserts are set with the index tabs facing up or down.
The diff height adjustment is mainly to affect the driveshaft angle. Higher diffs = straight driveshafts which have less resistance on power. Also it is used on carpet because the tires are much smaller, therefore the outside axle is lower and thus the diff should be lowered.
Mainly you will lower or raise the front diff to get different steering characteristics. On carpet you would lower the front diff to tame down the front end. On asphalt you might raise it to get more steering.
kdub is offline   Reply With Quote
Old 07-03-2007, 10:33 AM   #3257
ttso's Avatar
Is diff height only to make drivetrain straight? Or it as a setting option? Which one should go first? as straight as possible to get more efficiency? or use as setting option?
If I read it right, straight drivetrain = more traction??
ttso is offline   Reply With Quote
Old 07-03-2007, 09:51 PM   #3258
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
anybody have an asphalt set up with only a itf top deck. and how to make d front diff into a spool? cut a sand paper and replace d diff ring?
pinggoy is offline   Reply With Quote
Old 07-03-2007, 10:29 PM   #3259
smostyn's Avatar
Trader Rating: 9 (91%+)
Default Bearings
Looking for some spare bearings and was hoping to find some locally. Or online.
10x15x4 No problem, can find them anywhere.
8x4x3 Again, no problem.
6x10x4 BIG PROBLEM. Cant find them. I guess that they are not a common size.
These are the wheel hub bearings, 8 in total on the car.
Any help?
Shayne Mostyn
Meakin Park Model Raceway, the best club in SEQ
I am no longer racing. Now I plan to bash around on a larger scale.
smostyn is offline   Reply With Quote
Old 07-03-2007, 10:36 PM   #3260
EricF's Avatar
you can use sand paper or some use header cards from parts bags. Both will work. with the header card I'd think you'd need to have the thrust bolt tighter than normal.
E
EricF is offline   Reply With Quote
Old 07-03-2007, 11:16 PM   #3261
@EA: i drive the car 25-30 times i think, but the front belt is tight and i can play music with it. i think there is something wrong in my package of the car. Anyone have a idea wich belt is fiting also???
BlueSilver is offline   Reply With Quote
Old 07-04-2007, 10:46 AM   #3262
Any of you guys noticed any abnormal wear in the CVA joints, mainly where the crosspin drives the axle, but also a little where the coupler and bone meets? I've got three race days on my car, I think I would have rather had a thicker axle instead of the retaining clips.
chance is offline   Reply With Quote
Old 07-04-2007, 10:49 AM   #3263
51
51's Avatar
Do you have a friend that has a TC5 that you can compare with? It is highly unlikely that you have a "short" belt?
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 07-04-2007, 11:15 AM   #3264
mainracer's Avatar
Send a message via AIM to mainracer
chance- I have run over a 100 pack on the car and I just rebuild them yesterday and I had no slop at all. one thing I do is I put a lot of black grease on the join and that seems to help.
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 07-04-2007, 11:15 AM   #3265
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Please don't take this as insult to your building, but the first thing I would do if make sure that the setting you assume to be the loosest is just that. Do you have the notches for the cam facing up or down. If the notch on the cam faces upward, make sure they point toward the front bumper and not toward the rear of the car. Also check to make sure that the notch isn't in different settings right and left. Having the diff slanted due to different settings left and right could bind it up. Maybe this helps,if not, like Brent said, set it up the same way with some one elses belt?
Brandon Melton is offline   Reply With Quote
Old 07-04-2007, 11:19 AM   #3266
Chance- like Keven said, use the black grease in all the joints. I used to always run my CVD's dry because I feared the grease would attract dust and dirt from the tracks we run on not being prepped. I too noticed wear when I ran them dry, but I have used grease ever since with no further issues. Without the grease mine would also bind up when the axles turned left and right, which unless you had the servo unattached you wouldn't notice.
Old 07-04-2007, 04:30 PM   #3267
Thanks, I'll keep an eye on them. I feel like there's more than enough black grease still in them to prevent this much wear. It's mostly just the fronts, I guess it's from running a spliff from the start, never did run it with a front diff.
No worries, fast as this car is, I can live with it.
Old 07-04-2007, 04:58 PM   #3268
Yeti35's Avatar
Originally Posted by Knight Rider View Post
Here's a setup question, when the track starts to get greasy from the heat, and the rear end decides that it's time to srart drift racing, what change would you suggest to help lock the rear end back in?
For you, just pack up and go home, you are done for the day!!
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 07-04-2007, 07:07 PM   #3269
51
51's Avatar
One of our team drivers reported that he liked to lower the inner rear camber link when the track got a bit more slimy. This helped lock the rear in more.
Old 07-04-2007, 10:19 PM   #3270
Suspended
i race in arizona, where the temp is over 100 degrees when we race, have had the same problem with rear end swapping around, Brent said it was front end too soft, but the change that made the biggest improvement was to actually raise the inner hinge pins to the upper mount, seems like it wouldnt work but makes the car have almost too much rear traction, i guess it doesnt lean as much but it works
i am cornholio is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
