Old 06-28-2007, 04:58 PM   #3196
droop gauge is good too. It's probably a bit more accurate, but this way is quicker. You don't have to remove your tires.
DOTMAN is offline   Reply With Quote
Old 06-28-2007, 05:45 PM   #3197
Maybell's Avatar
very well said Dotman!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 06-28-2007, 06:58 PM   #3198
SoCalMitch's Avatar
What is the best way to make a spool out of the front diff? All the parts I needed came in except the spool and I want to race it Saturday at BCR.
SoCalMitch is offline   Reply With Quote
Old 06-28-2007, 07:03 PM   #3199
Trader Rating: 38 (100%+)
Take the diff balls out.
or8ital is offline   Reply With Quote
Old 06-28-2007, 07:35 PM   #3200
Super Moderator
Marcos.J's Avatar
Trader Rating: 167 (100%+)
this is the best way
Originally Posted by AdrianM
To make a diff into a spool:
1. Disassemble a diff but leave the thrust bearing in the female out drive alone.
2. Remove the diff balls and clean all the silicone diff lube from the pulley, diff rings and out drive faces.
3. With thin CA glue header card stock to one side of the diff rings. Cut them out so that one side of the ring is faced with paper.
4. Reassemble the diff with no diff balls and the paper side of the diff rings facing towards the pulley. The paper takes up the space normally occupied by the diff rings so the width of the spool is correct.
5. Adjust the Spool/Diff just like a diff. Full tight then back off 1/4 turn. This will allow the spool to slip and dissipate energy during crashes. It will NEVER slip while racing, only during crashes.
Old 06-28-2007, 07:42 PM   #3201
I should be out there aturday as well. Silver and blue paint. I need to build a spool as well.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 06-28-2007, 07:47 PM   #3202
AdrianM's Avatar
Making a diff into a spool is great because it can give if you crash.
I am not familiar with the TC5 but if the diff outputs are plastic this will not work. They just aren't strong enough. If the outputs are steel you are good to go.
Old 06-28-2007, 07:55 PM   #3203
Super Moderator
Marcos.J's Avatar
my bad i forgot about the outputs
Old 06-28-2007, 08:10 PM   #3204
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
You can make a spool out of the standard front diff.
1. Do not install diff balls
2. Assemble the diff as per instructions (except diff balls and grease on pulley)
3. Use Dremel sanding discs - mark out the size first, the outside diameter is correct, you just have to mark and cut out the inside diameter (making sure that the smooth side is facing the diff plates)
4. Tighten up diff fully
** Optional only: make sure outdrives are lined up with each other - use slots. The reason for this is that you can see how much your spool has moved after a crash, and readjust (retighten) if required.
I have run a spool like this since the car came out and have had no issues (ie. breakages or spool letting go).
Hope this helps.
- Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 06-28-2007, 08:48 PM   #3205
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
hi guys just got back from a long time off from racing..and the the tc5 is the one that caught my eyes because of the price and this is a new development of ae. . althought i was a little bit disapointed of the tc4 (just dont ask why).
just wanna know if tc4 parts are compatible with this.
has anybody race this car asphalt ,tight, mid - high traction track?
any best setups recommended? from the list of setups on the ae site?
any tips? i read about the o ring on the top deck.
thanx guys
pinggoy is offline   Reply With Quote
Old 06-28-2007, 08:48 PM   #3206
highwayman's Avatar
i assembled my spool, without the trust balls... i replaced them with another washer to make up for the space difference... hope this helps - jason
highwayman is offline   Reply With Quote
Old 06-28-2007, 10:11 PM   #3207
A few of the diff parts are the same, and the shock springs. Thats about it.
It is a new car from the ground up and it is all metric.
thanx guys
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 06-28-2007, 10:35 PM   #3208
pinggoy's Avatar
thank you ..
i was looking at the set up on rc10.com ryan had his ride height set at 5mm and had his droop at 5mm so that means there is no droop?
Old 06-28-2007, 11:23 PM   #3209
B4Bandit's Avatar
Originally Posted by Chris Reilly View Post
Why flame anyone? I would hope people have something better to do with there time.
Coz it's fun. I guess it's just our sense of humor... hard to explain really, but it's all done in gest. It all passes in general conversation.
I think it's kinda like the humor in that TV show "How I Met Your Mom" in a way, in some ways like the Simpsons and in some ways like Seinfeld. We have a running satire the whole time, and we are the stars of the show. I think that it helps us see the faults within ourselves plus it also lets us know that it doesn't matter to our mates.
I'm sure that guys in the States do it too and you would get it. I think that the word flaming might come as a bit serious. In our environment, it's pretty easy to know when the insults become serious. The language is the same, but the delivery is different.
B4Bandit is offline   Reply With Quote
Old 06-29-2007, 02:31 AM   #3210
Albino2000's Avatar
Hello!
I want to buy me a TC5. The car will be used on carpet.
What kind of (usefull) tuning will I need?
Can I use the spring set from the TC3/TC4 or is there a new one for the TC5?
Albino2000 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
