Old 06-25-2007, 07:47 PM   #3181
Brandon, Durham would be better, it would most likely be a better starting setup for me at Rosewood. Thanks
chance is offline   Reply With Quote
Old 06-25-2007, 09:53 PM   #3182
highwayman's Avatar
i made my diff into a locked spool and it held up pretty well in 19T.
highwayman is offline   Reply With Quote
Old 06-26-2007, 07:54 PM   #3183
Verndog's Avatar
Trader Rating: 16 (100%+)
Default Ready for test run
Well after vacation, then indecision on motor -- ect. I finally got it together. I started with a Paradox 27T and will wet my whistle on that, and decide which BL to go to later. A friend of mine convinced me learning with my MM7700 on the SIR indoor track was a bad idea...prob. good advise. Anyway I will try it out Thurs. eve for first real run...wish me luck! Thanks to those that helped and gave S/U advise...let the fun begin!
Couple of pics of finished car.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-26-2007, 08:47 PM   #3184
Are any of you guys running 10.5 bl systems? The Peak one is supposed to be geared about 5 to 1 fdr so i bout a 34 tooth and i does not fit. i kind of want to switch to 64 pitch anyway so does 100/40 fit?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 06-27-2007, 12:55 AM   #3185
ooliganRC's Avatar
Send a message via MSN to ooliganRC
sure will, i fitted 120/42 on 64dp.
ooliganRC is offline   Reply With Quote
Old 06-27-2007, 04:58 AM   #3186
I think that you'll find that 100/40 is going to be pretty close to not fitting. 108/43 should give you enough room to gear up and down a little from where you're starting at.
For me, the bigger spurs work better because it moves the motor foreward in the car. I think PRS is going to make pinions up to 60... Robinson goes up to at least 45.
Unregistered is offline   Reply With Quote
Old 06-27-2007, 05:18 AM   #3187
ooliganRC's Avatar
good to see people read all threads, 120 spur fits, with a max size oinion of 41 (64dp), which is idea for mod/brushless as 120/41 gives 5.85 fdr, would suggest a 116 for stock/19T as it drops the fdr to about 5.1 with a 41 so all ranges possible.
would only use smaller if running silver can 540 motors
Old 06-27-2007, 09:58 AM   #3188
I think I read his post...
I've also run the higher wind 13.5 and 10.5 brushless motors in the TC5. You need a pretty small spur to run them. Or really big pinions that most people don't have.
FYI, 116/41 is a 5.85 and not even close to the 5.00 to 1 that he's looking for as a starting point. 5.0 overall would need about a 46-47 pinion and most people don't have gears that big.
Old 06-27-2007, 10:18 AM   #3189
Trader Rating: 45 (100%+)
I ran a 34 pinion and a 87 spur, It fit just fine.
Kingsbury is offline   Reply With Quote
Old 06-27-2007, 07:20 PM   #3190
I ended up 104/40 and its fine.
FT B44 - FT J82
Old 06-27-2007, 09:43 PM   #3191
Dadaman's Avatar
Trader Rating: 20 (100%+)
Originally Posted by fatbear View Post
If you want to have a look at how bad Australian flaming is just look at most of the popular threads in the Australian section of RC Tech.The 4wd Offroad thread is always a good one. But most of them make interesting reading.
They go at it like no other people I have seen.
I am an Aussie and I will be the first to back up this statement. The Aussie forums are a top read if you have a spare couple of hours. Sorry to say it, you guys just don't flame like the true blue Aussies.
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 06-28-2007, 12:25 PM   #3192
Why flame anyone? I would hope people have something better to do with there time.
Chris Reilly is offline   Reply With Quote
Old 06-28-2007, 04:42 PM   #3193
Send a message via MSN to Grindog001
Hi all, i am a little confused how the droop is read on the setup sheets? It states 1 mm for the front and 2 mm for the rear and it is measured above ride height. Does this mean that if i am running a 5mm ride height, i would simply rest the chassis 6mm from the bench, then wind the droop screws until the front wheels are just touching the bench? Then raise the chassis to 7mm from the bench and adjust till the rear wheels touch the bench?
hope this makes sense, thanks, john
Grindog001 is offline   Reply With Quote
Old 06-28-2007, 04:49 PM   #3194
Basically, yeah...if your ride height is 5 then 1mm over means your tires will lift off the ground when your chassis is lifted over 6mm
DOTMAN is offline   Reply With Quote
Old 06-28-2007, 04:52 PM   #3195
ok, thanks. is this way more accurate than the droop guage?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
