Old 06-18-2007, 01:00 PM   #3106
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Advil View Post
The Futaba 9550 and the KO 2343 do not fit the kit mounts.
Yes but Airtronics and JR ones do. I used the narrow mounts on mine from a B4 and my 9550 fit perfect....I think those are the mounts the kit is going to be updated with as it will allow the use of any servo.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-18-2007, 01:07 PM   #3107
nutsisneat's Avatar
Hello guys
I finished my TC5 two days ago, i have two questions:
How can i fix my orion Lipos? I need something for the corners (like xray offers for the FK05) I want to use the strap and not tape.
Where can i buy a one way, a spool and maybe an itf chassis? All shops
and the bay are out of stock.
My comments to the kit: not the same quality like an xray, but very good, good enough. But i think the COG is very high compared to other actual cars like let's say Corally phi or MI3.
I'm wondering how the car will perform.
Regards from switzerland...
nutsisneat is offline   Reply With Quote
Old 06-18-2007, 01:15 PM   #3108
Trader Rating: 17 (100%+)
Originally Posted by cannon View Post
Wow ... got my TC5 kit and what can I say. It is such a high quality kit that I relegated it to the garbage bin. Would have to rival the JRX-S for poor quality kits. Poor fit and quality, doesn't even fit the current generation servos without dremelling and drilling. Way to go Associated !!!!!
I afraid I will have to disagree with you on this. The only thing that might have been a problem was servo mounting. Other than that ONE thing this kit is MILES above the last AE kit I assembled (TC4) and required no "hand fitting" of components other than for my personal choice of servo. This kit is easily on par with the last car I assembled....and that thing cost waaaay more than my new AE kit.
FWIW
Advil is offline   Reply With Quote
Old 06-18-2007, 01:17 PM   #3109
JCB
JCB's Avatar
Hey Guys,
I was able to mount the KO 2173. I just dremeled the inside of the servo mounts and it mounted just fine. I also ran the car this past weekend on carpet (medium bite) with foam tires. Box setup, the car ran great! I used double pinks front and rear. I probably ran 16 packs with 19T and had no issues with the diffs. Just tighten them down and then back them out 1/4. Hope this helps.
JC
JCB is offline   Reply With Quote
Old 06-18-2007, 01:18 PM   #3110
EA
That's what I did too Eric. I had some left over from my older AE cars. I was able to get one of my 9550s to fit in once I changed the mounts out.
Old 06-18-2007, 01:38 PM   #3111
EricF's Avatar
Default Battery Strap
EA,
Put a bug in B.T.'s about elongating one of the holes on the battery strap. That way there's less chance of the strap causing a tweak.
E
EricF is offline   Reply With Quote
Old 06-18-2007, 01:47 PM   #3112
fatbear's Avatar
Send a message via Yahoo to fatbear
Shayne ... you are bad. They will think we all talk like that with that post
Fatbear ... you need to understand Australian humour. The offroad guys are just having fun. They are all mates. Australians will tend to have a go at each other but generally without malice. This year at the TITC event in Thailand we sat with Scott Ernst and Jilles Groskamp. By the end of the week , Scott was understanding that we pick on each other all the time in good humour. Jilles however was threatening to spray us with motor spray if we didn't stop picking on each other
I am sorry that I have offended anyone with my comments. The car was simply a disappointment in relation to quality. I should have assumed I would have been blasted if I made a comment about it.
Cannon, I do understand Australian Humour. We have basically the same humour in NZ. Now it is you that isn't getting me.
fatbear is offline   Reply With Quote
Old 06-18-2007, 02:17 PM   #3113
Originally Posted by jeff john View Post
I had basically the same problem except I had 5 b-cam holders and 3 a-cam holders.
Looks like someone in AE quality control only likes odd numbers
DOTMAN is offline   Reply With Quote
Old 06-18-2007, 04:17 PM   #3114
Glowster21's Avatar
Trader Rating: 116 (100%+)
How has the car been performing on carpet? Thinking of getting one to try but I only run on the rug and want to get some opinions before I take the $350 plunge.....
Glowster21 is offline   Reply With Quote
Old 06-18-2007, 04:33 PM   #3115
dawgmeat's Avatar
never stopped you beforegood luck with your future races
dawgmeat is offline   Reply With Quote
Old 06-18-2007, 04:35 PM   #3116
Super Moderator
Marcos.J's Avatar
Trader Rating: 178 (100%+)
actually $320.00 if you buy from towerhobbies
Old 06-18-2007, 04:51 PM   #3117
Trader Rating: 19 (100%+)
What servos people are using without any modification for the TC5.
zake540 is offline   Reply With Quote
Old 06-18-2007, 04:53 PM   #3118
Super Moderator
Marcos.J's Avatar
a friend of mine uses the futaba9550
Old 06-18-2007, 05:00 PM   #3119
dbmartin's Avatar
I am running the 9550 w/o any mods. Of course I also am the one that melted my diffs, but thats a whole other issue. And yes I only backed it out a 1/4 turn, just like every other diff I have ever built w/o issues. On a brighter note, I ordered the spool/alum diff, just waiting for them to arrive. I also ordered the outdrives to build the stock ones back up. Nice that they are only $6.00 for 4 outdrives.
? for the those that may know. What is the size of the diff nut?
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 06-18-2007, 05:07 PM   #3120
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Stockman View Post
Hi,
I've just build my TC5 but I found three short outdrives and just one long outdrive:s:s:s
SO I cant build the two diffs!!
Does anywone also has this problem?
And does anywone know where I would find the spool kit or diff kit?
I wondered this after reading your post. Are you refering to PN 31167 diff. outdrive? They only list one length which is wrong (unless they come in a kit). I wondered if I had an issue, as the drive dogs on the CVD's are very close to the outer retaining ring of the outdrive. I can tell that with a BL setup I will be looking for the alum. upgrades there.
I'd call the sales (only # listed I can see) # 949-544-7500 pacific time.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
