Old 06-15-2007, 02:18 AM   #3031
S_fender's Avatar
Originally Posted by LOSI123 View Post
do tc4 springs fit the tc5 are they the same?
Yes
S_fender is offline   Reply With Quote
Old 06-15-2007, 02:41 AM   #3032
LOSI123's Avatar
Trader Rating: 63 (100%+)
thanks , also are the tc3 springs the same too ?,
as all i can find available on tower is tc3 springs
LOSI123 is offline   Reply With Quote
Old 06-15-2007, 02:50 AM   #3033
what other 1way would fit a tc5 ? , seens how no one has the proper 1 for the tc5 in stock.
MoonTrap is offline   Reply With Quote
Old 06-15-2007, 04:50 AM   #3034
Originally Posted by MoonTrap View Post
I see the internal ratio is 2.0 , is their any way to get it lower, with maybe a different diff pulley from somewhere, as i would use the car in 540 class and need to get to a 4.0 FDR
You shouldn't have any problems getting that low with the 2.0 internal. I haven't tried it but you can get to about 3.75 with an 88 spur and 37 pinion. Should be low enough for just about anything.
Unregistered is offline   Reply With Quote
Old 06-15-2007, 04:51 AM   #3035
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
yes, tc3,4,5 all use same springs.
Brandon Melton is offline   Reply With Quote
Old 06-15-2007, 04:53 AM   #3036
I beleive the one way from the Yokomo BD will work, but you have to shim it differently as the bulkhead spacing isn't the same. If you do this, make sure while shimming that the pulley stays in line with where it was and that that it doesn't line up too much in the center of the car.
Old 06-15-2007, 06:07 AM   #3037
ooliganRC's Avatar
Send a message via MSN to ooliganRC
bd one way and spool with pulley fit.
just need to shim on the motor side of the car abot 1.5-2mm of shims...works a treat
ooliganRC is offline   Reply With Quote
Old 06-15-2007, 08:01 AM   #3038
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
I heard yokomo's spool suck
King of B Main is offline   Reply With Quote
Old 06-15-2007, 08:47 AM   #3039
Hello,
thanks
I'm using a 48 pitch 72 tooth spur with a 35 tooth pinion and have a FDR around 4.1
home13oy75 is offline   Reply With Quote
Old 06-15-2007, 08:52 AM   #3040
Cyclone Charlie's Avatar
It's raining what a wonderfull day to race indoors!
Cyclone Charlie is offline   Reply With Quote
Old 06-15-2007, 09:04 AM   #3041
EricF's Avatar
Rain... It's going to hit 105 today. Good thing there's an indoor track here also.
E
EricF is offline   Reply With Quote
Old 06-15-2007, 12:38 PM   #3042
Send a message via MSN to Grindog001
Does anyone know if a KO 2343 will fit this car? i have heard that some servos are not fitting with stock servo posts
thanks, john
Grindog001 is offline   Reply With Quote
Old 06-15-2007, 04:08 PM   #3043
Verndog's Avatar
Trader Rating: 16 (100%+)
thanks, john
Ditto that...I'm going to pick up my servo this weekend and would like some feedback on what is working and fitting for others as well.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-15-2007, 10:20 PM   #3044
STARSCREAM's Avatar
lets ask the team.....
Hey Brent, what swervo are you running? and did it take any grinding to get it in the car? What about you EA?
I have a futaba S9350 in my car....but the fit is REALLY tight...I am going to change servos because I am a little concerned that it is tweakn my chassis...
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 06-15-2007, 11:24 PM   #3045
Verndog's Avatar
I was reading the manual after doing some building and noticed a whole list of servo's listed. Looks like the main purpose is to guide shim size and crank arm to use. Guess that doesn't really assure us a good fit. I really dont want to have to grind anything...especially since I'm going to buy a new servo...so I'm all ears on what fits best.
Got all shocks, diffs, steering crank, and turnbuckes together this eve...going well so far...
One thing I'm a bit disturbed about...why on gods green earth did they mix SAE and metric hardware in the same kit?? To put it nicely...that was a very silly decision IMO.
Hey Sean...do you know Geno at the Covington store?? I'm a good customer of his.
---Team Hoarders---
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
