Old 06-12-2007, 04:58 PM   #2986
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Originally Posted by josh short View Post
is there a Pdub bumper or something close to that for this car yet?
the losi one works
Old 06-12-2007, 05:00 PM   #2987
AdrianM's Avatar
I am sure PDub is on this and will have a TC5 bumper really soon.
Old 06-12-2007, 05:07 PM   #2988
using the stock gearing that came with the tc5, what pinion do you guys suggest for t a tc spec esc and a vector 3.5 motor?
bretzkej is offline   Reply With Quote
Old 06-12-2007, 06:32 PM   #2989
Originally Posted by NUCRPTRACER View Post
I love the TC5 way to go AE......Can anyone recommend or tell me which setup station is the best bang for the buck and do any have scales to try and balance?.....sorry this off the subject butt it is for my TC5....Thanks
Both the hudy and integy both make good ones.
As far as balancing goes, with 6 cells my car is pretty dead on. With a Lrp tc spec speedo and 2 fans on the motor. Also the transponder is in front of the battery.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 06-12-2007, 06:35 PM   #2990
Kyle ran 21/87 with 5 cells at the Reedy race.
Old 06-12-2007, 06:44 PM   #2991
Trader Rating: 21 (100%+)
Default Tc5 the best
First post on this.Probably the best car I've ever owned right out of the box.Now to fine tune.Anybody have any tips on getting"no rebound" on the shocks? Also,when speaking of "no rebound"does that mean No shaft rebound or Just no rebound foams? Petty sure I know the answer just wanting to be sure.Thanks to AE and the development team for sure.The box setup is awesome. Just want to learn the car now.Can't wait for carpet season or a race to come up.
lotus1 is offline   Reply With Quote
Old 06-12-2007, 06:51 PM   #2992
I finally got to run modified foam on carpet with the production car this past weekend. I was very impressed with the results. Every change can be felt and seen in the laptimes. Here is what I have came up with.
Front-
60 wt oil,#3 piston, purple spring
#2 hole in tower,A arm hole
6* castor blocks
#3 hole for camber link
1,A for steering link
med low diff
5mm droop
Rear-
40 wt oil,#2 piston, red spring
#3 hole on tower, B hole in arm
1/2* hubs, 2* inboard toe
A, 3 camber link-- 3mm shims on black ballstud
med low diff
4mm droop
Dna body, Jaco dbl pink tires w/ paragon full rear and 1/2 of the front tires.
Walter
Old 06-12-2007, 06:57 PM   #2993
Yes you are correct, when it is said no rebound, that means no foam.
If you don't use foam you will get pretty much no shaft rebound unless you have too much oil in the shocks.
Old 06-12-2007, 07:34 PM   #2994
Front-
6* castor blocks
med low diff
5mm droop
Rear-
Walter
Hey Walter,
I haven't seen you since the Reedy Race in 04'. Hope all is well. I might have to try your set-up.
Lex Tyler
Lex Tyler is offline   Reply With Quote
Old 06-12-2007, 07:41 PM   #2995
Default Cool
Thanks.Mario.
Old 06-12-2007, 08:18 PM   #2996
Special"ED"'s Avatar
is this what everyone keeps talking about when they say to add top deck washers?
Originally Posted by RandyB View Post
thats a picture of Juho's car at LRP I think. They didnt have spares for the cars so he had to put on tc4 parts. And since the tc5 is metric he had to replace a bunch of stuff in order for the tc4 parts to fit.
Special"ED" is offline   Reply With Quote
Old 06-12-2007, 10:04 PM   #2997
Finally got the electronics mounted and got to run a little, mind you it was just in front of the house to dial in the radio. I had forgotien how fast touring cars are! Has anyody seen any of the asphalt type parts in stck yet?( spool, top deck etc) It also got me thinking who will be the first to market with hop ups. I know it does not really need anything, just want to be different i guess. My YZ450F works way better than i could ever take advantage of but that does not mean i would not love to have Grant Langstons factory bike!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 06-12-2007, 11:58 PM   #2998
Cyclone Charlie's Avatar
What size pinion would you suggest for C027 motor for a track that the longest straight away of roughly 60 feet. The rest of the track is all turns with one other short straight. I've tried a 27 tooth pinion and it feels pretty good, but someone else told me they were running a 17 tooth. Seems kind of small to me.
Do you think I should try a 25 tooth?
Cyclone Charlie is offline   Reply With Quote
Old 06-13-2007, 05:41 AM   #2999
AM03GT's Avatar
running foam tires? rubbers? i think my local track is setup similar to the dimensions you are describing... try starting at a rollout of 26.5-27mm
AM03GT is offline   Reply With Quote
Old 06-13-2007, 06:15 AM   #3000
I found a place that answered my question. If anyone is interested here's the link to it:
http://www.rcuniverse.com/forum/m_3255405/tm.htm
According to what I came up with there, I should use a 22 tooth pinion.
Thanks for your reply.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
