Old 06-11-2007, 05:22 PM   #2971
RandyB's Avatar
Originally Posted by zacabrandy View Post
Is there going to be an Asphalt version of this thing sometime this decade? It's a big waste of money for us in Australia as we race 90% on outdoor asphalt tracks...............................and I want to see how good this thing is against the very very impressive Mi3, Scythe and MS Cyclones..............cause at the moment it's way off the pace
Smoke crack much?
RandyB is offline   Reply With Quote
Old 06-11-2007, 09:27 PM   #2972
JCB
JCB's Avatar
Hey Guys,
Any ideas when the TC5 knuckles and rear arms will be available? Looking to go back indoors this weekend, but I can't find knuckles for spares... I checked a few website, but no luck.
Thanks in advance,
JCB is offline   Reply With Quote
Old 06-11-2007, 11:25 PM   #2973
Anyone know if the TC4 front caster blocks will fit on the TC5?
home13oy75 is offline   Reply With Quote
Old 06-11-2007, 11:53 PM   #2974
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Default some tips.....
Originally Posted by mi2dude View Post
Guess this means gold front blue rear?
Originally Posted by AM03GT View Post
those are the accessories you may need... i would add a pair of silvers to that list as the baseline setups for asphalt usually start at gold/silver or blue/silver...
Sorry my bad. An oversight there. Yes, the addition of silvers will help. And they are only recommended accessories for asphalt racing. The car does work in stock form, just needs a bit of work.
The biggest thing I have noticed about the TC5 is that sway bars are not required to run on asphalt (rubber tires). I have tried both (with and without sway bars) and the car not only feels better but is also more consistent and yields faster lap times without sway bars. (unlike any other TC I have had before) - it also does not seem to 'pitch' or roll through corners.
A couple of other observations I have made over the past month are:
1. likes Mazda 6 body over any other on asphalt/rubber tires
2. on med-high grip asphalt tracks, standard bottom deck and itf top deck (o-inc. ring mod) yields great results
3. seems prefer softer dampening (#2 piston) - faster piston speed = greater frt/rr weight transfer
4. when building the diffs,
a.make sure you apply small amounts of grease on the backside of the plate and that the plate is firmly and correctly secured (sharp edge against plastic)b.make sure you do the diff up tight as per revised manual
- to avoid diff problems
5. take out the bump steer with washers under the ball studs on the spindles (2-3mm)
6. check steering throw to make sure it is not excessive (ie. more than 24 degrees)
Hope this helps. Enjoy!!!
- Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 06-12-2007, 12:21 AM   #2975
corallyman's Avatar
Trader Rating: 97 (100%+)
Home13 and JCB,
TC5 2 degree caster blocks and rear arms are available at stormerhobbies dot you know the rest.
HTH,
Steve
corallyman is offline   Reply With Quote
Old 06-12-2007, 12:29 AM   #2976
JCB
JCB's Avatar
Originally Posted by corallyman View Post
Home13 and JCB,
HTH,
Steve
thanks, Caster block I have.. really need steering knuckes.
thanks again,
Old 06-12-2007, 12:34 AM   #2977
corallyman's Avatar
I havn't found anyplace yet that has steering blocks. I'm sure they will be out soon. Did you need rear arms though?
Steve
Old 06-12-2007, 12:46 AM   #2978
I broke my steering block and haven't been able to find any for sale. Do you think the TC4 steering arm will fit? I would hate to miss out on racing the car because I can't find a replacement block.
Old 06-12-2007, 01:06 AM   #2979
corallyman's Avatar
I know its possible, but not positive on what parts it will require. Juho did it on his prototype car. There are pictures of his car here and I think some explanation on it. Maybe somebody else that knows for sure can post or do a search.
I am going to build my car now that it arrived today
Steve
Old 06-12-2007, 09:11 AM   #2980
AM03GT's Avatar
Steve
it's possible, but not easy... Juho did not " do it" on his prototype car, thats how the parts were made for the prototype car... there's a difference... to use the TC4 steering blocks you need to fabricate an extension piece to get the same ackerman ballstud mounting locations. There is also the issue of using the standard bearings which will require the old cvd's...
AM03GT is offline   Reply With Quote
Old 06-12-2007, 09:50 AM   #2981
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
They will fit but it's not recommended as the bearings are different, the diff slots will be different, the axles are different, etc. You could do it but it would cost you a small chunk of change and you would have to modifiy the diff outdrive slot to fit the older pins....and then it would not work with the stock pins when you did get the correct parts to change it back.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 06-12-2007, 05:14 PM   #2982
Trader Rating: 19 (100%+)
Can anyone suggest a good servo for this car.
TIA
zake540 is offline   Reply With Quote
Old 06-12-2007, 05:21 PM   #2983
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
TIA
Futaba 9550
Old 06-12-2007, 05:34 PM   #2984
Default Opinions please
I love the TC5 way to go AE......Can anyone recommend or tell me which setup station is the best bang for the buck and do any have scales to try and balance?.....sorry this off the subject butt it is for my TC5....Thanks
NUCRPTRACER is offline   Reply With Quote
Old 06-12-2007, 05:54 PM   #2985
Trader Rating: 43 (100%+)
is there a Pdub bumper or something close to that for this car yet?
josh short is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
