Old 06-07-2007, 09:48 AM   #2836
51
51's Avatar
Originally Posted by EricF View Post
Brent,
What settings do you use if/when you run a brushed motor? For instance a 19t. I'm debating on which esc to use; Sphere or a Comp 2.
So far I really like the car. The build quality is a lot better, not as tight as xray but definitely not a loose as past kits.
Thanks,
E
The good thing if you go with the Sphere Comp is that in the future if you want to run brushless, even if it's the 13.5 (so called 19t equivalent) you already have the speedo to do so. If you are going to run brushed, I would start with the settings at 2/3/2/2.
Yea, there are a few loose fitting pieces in this first run, but over the next few months the molds should tighten up and everything will fit nicely.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 06-07-2007, 10:02 AM   #2837
Special"ED"'s Avatar
Default Preping the chassis
How much do you sand the battery slots? Also should you sand the sharp edges off the entire chassis. Also do you glue, CA the edges for protection.
ed
P.S. There is still racing in San Diego.
ChECK
3FAMILYHOBBIES.COM
Special"ED" is offline   Reply With Quote
Old 06-07-2007, 10:11 AM   #2838
Rick Hohwart's Avatar
ed
ChECK
3FAMILYHOBBIES.COM
I sand enough so that when I place a loose cell in the slot, it is flush with the bottom of the chassis. You can remove the sharp edges from the perimeter of the chassis before you glue them.
Rick Hohwart is offline   Reply With Quote
Old 06-07-2007, 10:22 AM   #2839
THANKS RICK
Old 06-07-2007, 10:35 AM   #2840
Cyclone Charlie's Avatar
I sanded all the sharp edges everywhere and CA'd them all. I paid extra attention on the battery slots and the places where you would use tape to hold the battery in. I even did a light sanding on the tape slots after I CA'd them. I don't use the battery strap that came with car because of the shortness of the hold down screws. Even with them installed per the manual they seem kind of short for my liking. Sanding and sealing all the edges makes for a nicer looking finished product.
Cyclone Charlie is offline   Reply With Quote
Old 06-07-2007, 10:38 AM   #2841
51
51's Avatar
Default Chassis Prep
This is the first time I've used this method, but it worked great. I chamfered all the square edges with a dremel on a very low speed and then using 300 grit sandpaper, wet sanded all the edges. It only took about 10 minutes to do the chassis, top deck and towers. I was very pleased with the results and there is zero chance of gluing your chassis to your shirt...ask Barry Baker about that one...lol.
Old 06-07-2007, 11:02 AM   #2842
RAP66's Avatar
I glue (thin CA) everything first to seal it then I wet sand all the edges with an med grit emery board (the one used for nails), when it's all done I'll re-glue all of the edges again.
RAP66 is offline   Reply With Quote
Old 06-07-2007, 11:50 AM   #2843
EricF's Avatar
Thanks B.T. I'll go ahead and put my Sphere in.
E
EricF is offline   Reply With Quote
Old 06-07-2007, 12:47 PM   #2844
dbmartin's Avatar
I rec'd my itf top deck today, but no chassis yet.
w/ the itf top deck and the regular chassis, should i still run the o-rings in the top deck, or should I be ok without them?
thanks in advance
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 06-07-2007, 01:12 PM   #2845
51
51's Avatar
thanks in advance
You can run it either way. The o-rings are a tuning option.
Old 06-07-2007, 03:35 PM   #2846
kufman's Avatar
Originally Posted by wallstreet View Post
Rick so it would be best to run the belts at the loosest position for a few packs on the first couple of shake down runs...... then adjust the belts and start tuning the car for the track.
My belts are pretty tight even in the loosest setting. I have run about 5 packs through with a mod brushless. If I change the tension setting, the belts play music like guitar strings! lol I guess this will take some time.
kufman is offline   Reply With Quote
Old 06-07-2007, 03:59 PM   #2847
pepecueva's Avatar
I know this has been discused alredy, but I cant find it, is AE going to release some other version of the TC5, like a team version or a RTR version?
pepecueva is offline   Reply With Quote
Old 06-07-2007, 04:02 PM   #2848
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
well, the current TC5 is listed as a FT TC5, so thats out of the question. and I think a few pages back Brent mentioned that they had no plans on producing an RTR... could be wrong tho... best to wait for he or someone from AE to confirm it.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 06-07-2007, 04:02 PM   #2849
RCpurplecow's Avatar
There will be no "Team" version, just the Factory Team TC5.
there you go....
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 06-07-2007, 04:53 PM   #2850
I want AE to here me out on this. I think there should be a team version so people with less of a budget can jump into competitive onroad racing without spending all their money on a chassis. A RTR would also be really cool.The more varieties, the more buyers AE can appeal to.
TEAM SRU
FT TC5
NoVak
rematch batteries
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
