Old 06-06-2007, 09:48 PM   #2821
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i am thinking its Ralph's car.. the orange tape and 5-cell lead me to that, as i saw he had a 5-cell deck on his car, and it is anno'ed an orange/copper color....
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-06-2007, 11:36 PM   #2822
corallyman's Avatar
Trader Rating: 97 (100%+)
There is some ITF chassis and topdecks in stock along with front arms at Horizon Hobby.
Steve
corallyman is offline   Reply With Quote
Old 06-07-2007, 03:49 AM   #2823
RAP66's Avatar
Originally Posted by EAMotorsports View Post
The notchy diff is kind of odd as all the diff's I built were butter smooth and stay that way for a long time.
yes the front belt is tight. I run mine in the loosest position (notch all the way toward the front on both sides). It will loosen up a bit once its been ran a few times.
EA
I have a diff feeling notchy as well. I rebuilt it a few times and the only thing I can figure is one or some of the diff balls have a flat spot. Looks like I use the diff in my second kit, until I get spares to rebuild this one
RAP66 is offline   Reply With Quote
Old 06-07-2007, 03:58 AM   #2824
B4Bandit's Avatar
Default Belt tensions
Can anyone tell me what difference a loose v's tight belt makes? The TC5 is the first belt car that I've driven...
Cheers.
B4Bandit is offline   Reply With Quote
Old 06-07-2007, 04:05 AM   #2825
RAP66's Avatar
Cheers.
tooo tight will cause to much drag on the drive train and could cause your electronics to heat up more than usual, it will draw more current and cause your run time to go down
too loose the belt might pop and slip - wearing down your drive train.
Old 06-07-2007, 04:30 AM   #2826
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by Kevin Boyle View Post
Brian,
As tempting as a beating would be this weekend, I am sorry to say I will not be at the Express Race.
The car will hit the carpet at Horsham first. I need to shake the rust off and see what I can do with the car.
Brent,
You need to come out next year for the EXpress Race.
Later
Kevin Boyle
Ok. I will be back at Horshem for the warm up race for Vegas to run some rubber tire stock or 19T. Not sure which one but if I can I will be down. Have to see when I'm getting back from vacation.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-07-2007, 04:57 AM   #2827
ooliganRC's Avatar
Send a message via MSN to ooliganRC
found another issue this morning.....
Fitting a ko 2174 servo doesnt fit the car.I take it only servos listed in the manual fit the car?
ooliganRC is offline   Reply With Quote
Old 06-07-2007, 06:19 AM   #2828
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
There are some servos that do not fit with the supplied servo posts. You can dremel the sides of the post flat to allow them to fit in closer, or I believe there are also posts used in the offroad vehicles that will make the servo fit.
Brandon Melton is offline   Reply With Quote
Old 06-07-2007, 06:24 AM   #2829
While the car is in it's newest stages, set the belts as loose as possible. Even in the loosest position it will not skip or cause pre mature failure if all cams are installed correctly.
One thing I observed is that if you are using the ITF chassis, running the belts in a too tight of a position will actually slightly bow the chassis upwards at the ends. Not so much with the top deck installed, but you want the chassis to be as flat as possible when in a static position, and the belts too tight want to pull the chassis in.
Old 06-07-2007, 06:52 AM   #2830
Rick Hohwart's Avatar
Cheers.
A tight belt (especially rear) will also result in excessive drag brakes which cause oversteer entering turns.
Rick Hohwart is offline   Reply With Quote
Old 06-07-2007, 06:56 AM   #2831
Fastforward's Avatar
That expains why my car was loose on the early test runs and now I am having to undo the chassis adjustments that I made to compensate for the loose condition. When I built my car I put both belt cams at the full loose positon and they were very tight. After one night of club racing they have losended up quite a bit.
Fastforward is offline   Reply With Quote
Old 06-07-2007, 07:57 AM   #2832
This is not directed at you but a general statement. Each driver must adjust his belts for proper tension in his car. There is no one adjustment that everyone will use. The setting will be different for each individual.
Old 06-07-2007, 08:00 AM   #2833
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Rick so it would be best to run the belts at the loosest position for a few packs on the first couple of shake down runs...... then adjust the belts and start tuning the car for the track.
wallstreet is offline   Reply With Quote
Old 06-07-2007, 08:04 AM   #2834
It is best to run them a little tighter than normal to start, this will help the break in stretching process. After a few packs they will be at maximum length and should not change much if at all from that point on.
If the loosest position is still too tight, run it that way and adjust later. Just keep in mind that a tight belt can harm your electronics if it leads to overheating.
Old 06-07-2007, 08:35 AM   #2835
EricF's Avatar
Originally Posted by 51 View Post
As for the Sphere Comp settings I ran 2/4/1/2. I also had my expo on both the throttle and brake at -10%. This just gave a bit better feel.
Brent,
What settings do you use if/when you run a brushed motor? For instance a 19t. I'm debating on which esc to use; Sphere or a Comp 2.
So far I really like the car. The build quality is a lot better, not as tight as xray but definitely not a loose as past kits.
Thanks,
E
EricF is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
