Old 06-04-2007, 10:36 AM   #2746
rcmark24's Avatar
Trader Rating: 14 (100%+)
Okay you've talked me into one! Nothing but asphalt around here though. I normally run foams but will the rubber tires work better?
rcmark24 is offline   Reply With Quote
Old 06-04-2007, 10:37 AM   #2747
51
51's Avatar
Originally Posted by corallyman View Post
Brent,
That's kinda what I figured, just wanted to make sure though. Are you personally gonna keep racing TC for awhile or is this just between big off-road events for you? The Nat's are up here in Seattle this year.
Thanks again for your help.
Steve
We have the electric offroad nats next week and then a few weeks later are the onroad nats. After the offroad nats I will continue to run touring car in preperation for the nats at SIR. Hopefully I'll get to run at least 3 times before the event.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 06-04-2007, 10:39 AM   #2748
On my way to get mine. What do i need that is not in the kit for asphalt? I may try the sanpaper thing for a spool right now and the orings to soften up the chassis but i dont know what size to get
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 06-04-2007, 10:49 AM   #2749
EricF's Avatar
Are you guys going to come out to CH and run some rug before Vegas?
Later,
E
EricF is offline   Reply With Quote
Old 06-04-2007, 10:58 AM   #2750
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Anyone has close-up pictures about the suspension blocks? I want to see if Associated has something on that area differently. I have too many bent screws (the ones mount the blocks) on my Xray T2.
Mike Schumacher is offline   Reply With Quote
Old 06-04-2007, 11:04 AM   #2751
Rick Hohwart's Avatar
I am not sure what size they are, but we use the shock o-rings.
Rick Hohwart is offline   Reply With Quote
Old 06-04-2007, 01:45 PM   #2752
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
I might have a picture that you are looking for here:
www.rctouringcar.com/tc5/
RoachRacing is offline   Reply With Quote
Old 06-04-2007, 02:01 PM   #2753
51
51's Avatar
Yep, just the standard #5407 o-rings work fine.
Old 06-04-2007, 02:02 PM   #2754
51
51's Avatar
I haven't seen too many bent screws on the TC5s. Most of this is due to the large footprint of the toe-in shims. The block is supported throughout as opposed to just where the screw goes through.
Old 06-04-2007, 02:03 PM   #2755
51
51's Avatar
Originally Posted by EricF View Post
51
Later,
E
I'm sure at some point we'll be out there testing. Competition Hobbies is still the best facility I've seen.
Old 06-04-2007, 02:16 PM   #2756
beta bob's Avatar
Trader Rating: 2 (75%+)
I learned one thing this saturday that no matter how good the car is it all depends on the driver. this guy came to our track and his tc5 was dialed and i just loved it when i ran one of his qaulifiers and i won that race beating the track record by 13 seconds and then during the a main he drove it and he lost to a kid who drives a sprint 2 rtr.( i was in the lead until the kid with the sprint 2 took me out)
beta bob is offline   Reply With Quote
Old 06-04-2007, 02:27 PM   #2757
B4Bandit's Avatar
Originally Posted by beta bob View Post
......when i ran one of his qaulifiers and i won that race beating the track record by 13 seconds and then during the a main he drove it and he lost to a kid who drives a sprint 2 rtr.( i was in the lead until the kid with the sprint 2 took me out)
Impressive!
B4Bandit is offline   Reply With Quote
Old 06-04-2007, 03:51 PM   #2758
JCB
JCB's Avatar
Mine just arrived. Should have have it done in a couple of days
Looking to run on carpet next week. Thanks again for the info...
Do you when the arms, knuckles, etc will be in stock?? Need to order spare parts.
JCB is offline   Reply With Quote
Old 06-04-2007, 05:11 PM   #2759
I looked around and it looks like Stormer has a good supply of parts. The only major thing I noticed they were out of was front arms and 4* blocks.
Alot of the rubber tire stuff is due this month
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 06-04-2007, 07:05 PM   #2760
The belts will stretch a little but the TC5 belts will do so less than others. But that is what the adjustability is for. They can always be set perfectly. The drivetrain should be very free, even with new belts. The important thing is to set the belts so that they are not too tight, regardless of the starting point given in the instructions.
The rear belt should have about 3/16" deflection and the front more. The front belt should be able to at least touch the top deck when pressed down.
You can't set the suspension until you have the car completely built with everything installed and the desired tires mounted (and trued to the correct size if using foam). It sounds like you have too much pre-load on the springs. This is OK for now and will be adjusted later anyway when you set the ride height.
See the AE website for the droop (down travel) settings as these will need to be set correctly before anything else and can be done before everything is installed.
I've got the same issue, the rear belt is really tight,I rechecked the diff bearing cam holders and their okay, any ideas? Also, I noticed the front belt runs really close to the bell crank post.
outlandr91 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
