Old 06-03-2007, 09:57 PM   #2731
STARSCREAM's Avatar
Originally Posted by corallyman View Post
I bet they were just overlooked, one hole is probably very common so far for the drivers, most likely the bottom hole. I'm sure by monday we will know.
Sean.....have you and I ever had the same type of car at the same time, I am thinking no. How's it going by the way.
Steve
I dont think we ever have... And its going better than EVER!!!!!thanks for asking....
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 06-03-2007, 09:58 PM   #2732
STARSCREAM's Avatar
Steve
Originally Posted by EAMotorsports View Post
If you are running your pins flat you will use the bottom hole on the bulkheads. I think the top hole is for when you are running anti/pro dive and anti/pro squat. It allows you to get a different combination of degrees.
EA
awww....that would explain it...
Sean Maybell
Old 06-03-2007, 10:02 PM   #2733
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by home13oy75 View Post
My car should be arriving sometime tomorrow. I've been following this thread and chose the TC5 based on the helpful online support that I've been seeing. Hopefully I'll be able to contribute one day.
Thanks again Corallyman for your help!
You're welcome Home13, just ask anytime you have a need somebody here will help. Quite a few of them too are even Factory Pros.
Steve
corallyman is offline   Reply With Quote
Old 06-03-2007, 10:03 PM   #2734
corallyman's Avatar
EA
Eric,
Is this covered anywhere in the instructions, I have not gotten mine yet.
Steve
Old 06-03-2007, 10:28 PM   #2735
51
51's Avatar
Hello Brent (51),
I was looking at Ryan and Kyle's setup's from the Reedy Race and I was wondering which hole they are mounting the arms onto the bulkheads. The drawings show a (A, B,) hole and I am not seeing the corresponding marking on the setup sheet, am i just missing it or maybe it just got overlooked.
Also do you have Rick's setup from invite, I did not see it posted as of today.
Congrats on your finish also, its great to see everyone excited about the car and doing so well with it. Mine will be comming soon.
Thanks,
Steve Curry
Thanks for pointing that out Steve. It was an oversight. All the setups listed on our site are in the "A" arm mount hole. I will have our webmaster make the adjustment to the setups.
Also, I just got the setups from Juho and Rick and will be posting them early this week as well. As you can see, we were all very close to the same setup, just some personal changes to fit different driving styles.
Thanks for the congrats...it's great to be out here helping the public. I do quite a bit of it in electric offroad, but it's been a while since we've had a strong touring car presence, so the newfound attention is nice. Hope everything works out for you.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 06-03-2007, 10:40 PM   #2736
corallyman's Avatar
Brent,
That's kinda what I figured, just wanted to make sure though. Are you personally gonna keep racing TC for awhile or is this just between big off-road events for you? The Nat's are up here in Seattle this year.
Thanks again for your help.
Steve
Old 06-03-2007, 11:41 PM   #2737
Hi all,
guys i ran my car last weekend and it was amazing :-)
I start with the Setup out of the Box with Rubber Tires on Asphalt and i was wondering how much grip the Car have. After some changes the car was very easy to handle and i cant wait for the Spool, i was run the Diff Diff combi. I think with spool it is much better :-)
I driving with a Nosram 3,5 Turn BL and 5 Cells and after 10 runs i canīt find anything on the Car and nothing was damaged.
So guys...next weekend is a National Cup here and i will do my best, also i hope that the Spool comes and i can drive it there.
I will build my car with one of the Setups, like Juho or Brent dirving to see how tha car is handeling then.
Bye for now,
Marcel
BlueSilver is offline   Reply With Quote
Old 06-04-2007, 05:07 AM   #2738
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
EA
Eric would it be safe to say that the #2 arm mount in the lower hole would be like runnning the middle mount ( or 0 ) on your former brand ? And the #1 would be ultra low and #3 being high pin heights?
wallstreet is offline   Reply With Quote
Old 06-04-2007, 05:30 AM   #2739
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Correct to all. Check out the updated version of the manual available for download on the AE website.
- Leonard.
Explains all (arm mounts, toe shims, diff heights, diff settings)
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 06-04-2007, 06:34 AM   #2740
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Number 2 in the lower hole is like running number 3 in the other. About 8mm hinge pin height which is exactly where you want it for most surfaces. Ultra low on the the Corally is 8mm.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-04-2007, 07:12 AM   #2741
I finished building my TC5 last night. It was a beautiful thing, the way this car went together. I did have a slight problem with the top deck holes for the attenna mount, but I reamed them out with the dremel and was OK after that.
AE, thanks for putting together such a great car. I can't wait to get it on the track this coming weekend. I'll soon be ordering another kit for my son.
One question - If I wanted to switch to 64 pitch gears, anyone have a suggested starting pinion and spur for a small, tight carpet track?
At least one used FTC4 going up on eBay by the end of the week.
Tim Morley is offline   Reply With Quote
Old 06-04-2007, 08:18 AM   #2742
Sorry...
I got the 64 pitch answer back on page 86 of this thread.
T
Old 06-04-2007, 09:11 AM   #2743
wallstreet's Avatar
EA
wow... so the tc5 is going to be super adjustable for pin heights ... thats pretty awesome.... ill have my car out this weekend.
Old 06-04-2007, 09:14 AM   #2744
Team EAM
I just read what I posted. What I should have said is #2 on the TC5 is almost the same height as #3 on the Xray and is the same as Ultra low on the RDX. Right around 8mm.
EA
Contact Us
Old 06-04-2007, 09:31 AM   #2745
wallstreet's Avatar
thanks for the clearification.... to many questions while i am waiting for my kit. LOL
Either way still a ton of options for pin height
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
