Old 06-01-2007, 04:44 PM   #2671
51
51's Avatar
Originally Posted by tallyrc
we've been using larger (~7/8 dia) o-rings (instead of sandpaper) to make spools for associated cars for years... got tired of shattering the spools in the tc3's and 4's..
Is it possible for you to post a picture of how you have this assembled? Even if it's for a TC3/4.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 06-01-2007, 05:23 PM   #2672
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by RCpurplecow
thanks guys, i guess i'll stick with a one way because my car handles well with it, but i might try a spool when i get my tc5 in the near future.
Is the one way or spool out yet?? And where would it be possible to get the alloy outdrives from?
Regards
Nathan
NR is offline   Reply With Quote
Old 06-01-2007, 05:39 PM   #2673
tallyrc's Avatar
i'll see if i can put someting together (i switched car brands) but i think i still have a nitro diff here.. we used rubber o-rings that were the same size as the diff rings.. we used no diff balls or rings.. i wanna say the o-rings were #4 or #5.. gimme a bit to see what i still have in the old basement..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 06-01-2007, 05:43 PM   #2674
Trader Rating: 24 (96%+)
Default HELP HELP HELP HELP HELP
This is my first kit ever... my front drive belt rubs along the top deck the entire way down the body and hits into my servo saver.. I obviously did something really wrong but i cant figure out what...
please help
Team Associated TC5-img_4320.jpg   Team Associated TC5-img_4319.jpg   Team Associated TC5-img_4318.jpg   Team Associated TC5-img_4317.jpg
nemix is offline   Reply With Quote
Old 06-01-2007, 05:44 PM   #2675
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
please help
The belt runs over the top deck. Swap that and you should be good.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-01-2007, 06:01 PM   #2676
ha ha ha...
good joke eh?
I knew that
Old 06-01-2007, 06:23 PM   #2677
tallyrc's Avatar
it's your lucky day! i actually had to dig through my trash to get these parts as i'm in the process of moving, but..... i found the o-rings, a diff gear and both nitro diff halves.. the rings which are different sizes are ~.68-.69 (11/16")dia and the other is ~.88-.89 dia (7/8"). both are ~.08"thick.. the bigger went on the concave side of the diff gear and the smaller on the convex side.
Old 06-01-2007, 06:35 PM   #2678
51
51's Avatar
Wow...interesting...and that worked well for you? The o-rings never slipped and popped out of the outdrives? Man, the short outdrive looks very strange from that angle...I had to give it a triple-take to actually see the part. What did you use for the thrust screw/balls? Thanks!
Old 06-01-2007, 06:47 PM   #2679
dbmartin's Avatar
has anyone found the front arms in stock anywhere, Also does anyone know if the itf chassis/top deck are set to arive before next weekend, I have a 2 day race coming june 9th/10th and would hate to break an arm and be out of luck, plus I have a nice tc5 built, but have not mounted the parts to the chassis yet as i am hoping the itf arrives in time, both are on order among other parts from my lhs.
Thanks in advance
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 06-01-2007, 06:49 PM   #2680
tallyrc's Avatar
we just kept the thrust washer/balls and spring as they were from what i remember. i never had a problem with that setup ever, and after i broke a few of the cast metal spools, this was a dream.. infact you could "tune" it to "give" some if you wanted. the larger DIA o-ring fits within one of the grooves in the short diff half, the other is trapped by the gear itself..
Old 06-01-2007, 06:52 PM   #2681
RCpurplecow's Avatar
Regards
Nathan
sry dude, i was talking about sticking with the one way in my tc4, but the spool should come for the tc5 in about two weeks I think.
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 06-01-2007, 09:33 PM   #2682
B4Bandit's Avatar
I just got back from testing my new ride for the first time. Two words basically sum it up:
F*****G AWESOME.
Stock chassis, stock set up. Novak 13.5, rubber tires on asphalt. Beautifully smooth. A little loose in the rear entering corners, but that will be easily dialed... Only had time for two packs and no tinkering.
Thanks AE!!! Some of my mates who drive 007's/HPI were very impressed. Although it wasn't race conditions, I was all over them like a rash
We'll see how I go in a race...... Winter Champs at Whalan in Sydney, can't wait!!!
B4Bandit is offline   Reply With Quote
Old 06-01-2007, 09:35 PM   #2683
B4Bandit's Avatar
Probably couldn't have chosen a better car to start with
Old 06-01-2007, 11:10 PM   #2684
Hi Brent,
thanks for the Picture where i can see how i install the O-rings.
On this Pic i can see some intersting settings and i think that other guys will know it also.
1. Why is Juho using the TC4FT CVA bones?
2. Why is Juho using the TC4FT Rear Hubs? I have some of 3 Racing (Alu)here, it make sense to use this ones? Becouse they have more steps for different settings.
3. Why is Juho using the TC4FT Steering block?
4. is it better to have the reciever on the right site, where the batteries are located?
5. Is Juho using the thick Stock Chassie on this PIC?
When Juho is reading this here, i think he will answer all my questions :-)
Thanks guys for the great Support, i think we all will love this car :-)
Greetings,
Marcel
BlueSilver is offline   Reply With Quote
Old 06-01-2007, 11:32 PM   #2685
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
If anyone was wondering about the fitting the 4800 lipo in it. I would go in like this.
This is also how you shoe horn a GTB in the car too.
Corey
RoachRacing is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
