Old 05-30-2007, 07:12 PM   #2551
ErikRC10's Avatar
What ESC and motor is that?? The ESC is ginormous lol, looks kind of like the MM but is the wrong color, same with the motor it's the wrong color to be MM.
ErikRC10 is offline   Reply With Quote
Old 05-30-2007, 07:23 PM   #2552
STARSCREAM's Avatar
hey Team Associated drivers....tell me about this ITF chassis...
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 05-30-2007, 07:25 PM   #2553
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
The ITF Chassis and top deck are 2mm thick. They are for low-medium bite asphalt. The stock chassis is 2.5mm and the top deck is 3mm thick.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 05-30-2007, 07:32 PM   #2554
STARSCREAM's Avatar
gracias senior ea!!!
Sean Maybell
Old 05-30-2007, 07:35 PM   #2555
kufman's Avatar
It is a Schulze U-Force 75 controller and a Plettenberg Shadow motor. The controller predates the Mamba with slightly lower specs (6-12 cells, 75A cont). The motor also predates the Mamba and it a 4-pole, 2 turn. I believe the loaded Kv is something like 6200 with enough torque to run 30+ mm/rev rollout. In my TC3 I could gear it right around 6:1 for a large outdoor track.
The same equipment was in my car in this race
http://kufman.com/img/rc/AJs%202005%20Divx2.avi
I have the red and white van halen car. You can tell who I am half way through the race when I hit the wall. I then had to turn some fast laps to catch up.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 05-30-2007, 07:39 PM   #2556
Guess a Schulze!
http://www.schulze-elektronik-gmbh.de/index_uk.htm
Edit: To slow!!!
Arn0 is offline   Reply With Quote
Old 05-30-2007, 07:40 PM   #2557
Team EAM
No problem. While it might not be necessary for the price (around 60.00 for both) it might be a good idea to keep the ITF set on hand.
EA
Contact Us
Old 05-30-2007, 09:27 PM   #2558
Big B's Avatar
EA
Sean, that would probably be $money$ at SIR, I know the 2mm XRay topdeck is the way to go, I would suggest picking that ITF up, and for $60 you cant go wrong
Big B is offline   Reply With Quote
Old 05-30-2007, 09:38 PM   #2559
overflow's Avatar
EA
What are your thoughts on just running the ITF top deck? Think it would help as opposed to not at all. Or do you need both to really reap the benefits
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 05-30-2007, 09:42 PM   #2560
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
I had the same question. If I can get by with just spending $20, then I'd take that over $60 any day.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 05-31-2007, 12:28 AM   #2561
I have my TC5 on the way and was trying to figure out the gearing before the kit comes so I can have all my parts ready. I'm running a 13.5 Pro Novak BL system on a small tight track. I'm aiming for a 4.8 FDR. I'm just confused because I DL the gear ratio exel sheet that someone posted earlier on this thread and I thought I remember somone saying that the TC5 comes with a 87 tooth spur gear. So according to the chart, I need a 48 tooth pinion to achieve this. But on Tower's website the TC5 kit states that it comes with a 72 tooth spur gear. If this is the case - do you know which 48 pitch pinion gear do I need to achieve a 4.8 FDR?
Sorry if this sounds like a noob question but I don't have the manual yet and I can't DL the manual from AE's website. I just got into RC and I'm trying to learn. Thanks in advance.
home13oy75 is offline   Reply With Quote
Old 05-31-2007, 12:41 AM   #2562
corallyman's Avatar
Trader Rating: 98 (100%+)
Home13,
I don't have a kit yet but according to AE's website they list it as having a 87t spur. A 72t spur is a pretty small spur for a TC. That is about what a normal 1/12th scale car runs. Also that spreedsheet is written in 64p gears, the 48p spurs is in (). But when you read the pinions on the left those are 64p gears. For your 87t spur you would need a 36t
Steve
corallyman is offline   Reply With Quote
Old 05-31-2007, 01:37 AM   #2563
Corallyman,
Thanks for clarifying. I guess Tower's website had a misprint. I was just getting confused because it kept showing that customers that had purchased the TC5 were also getting the 48 pitch pinions which were 27t. Just to clarify - I will be purchasing a 64 pitch 36 tooth pinion for my 87t spur to achieve a FDR of 4.8.
Thanks again!
Old 05-31-2007, 02:36 AM   #2564
corallyman's Avatar
Home13,
You need to purchase a 36t 48p pinion to go with your 87t 48p spur that the car will come with. You can't mix and match 48p and 64p together. 64p has finer teeth, 48p less fine. 48p is more durable, 64p is alittle more efficient, but with the extra effiency comes more likely to strip or damage. 64p is fine in TC, its what I run but I have been doing this for more than 20 years. I suggest you stick with 48p, the teeth are bigger, stronger less likely to give a inexperienced guy hassles.
Here's your gearing situation in 48p.
87t spur divided by 36t pinion = 2.41666 times 2.0 which is your internal gear ratio.= 4.833
Steve
Old 05-31-2007, 02:57 AM   #2565
B4Bandit's Avatar
Originally Posted by WopArse
Hi B4bandit.
What your FT TC4 GTB 13.5 like,
I am thinking about buying that 13.5 GTB, is it any good.
Dose it drive like a 27 turn stock ???
Cheers
Wop
Hey Wop,
It's actually in my wifes car, which I only used for the first time at the last race meet. I thought that it was awesome! Real smooth, good speed and I like the way it coasts into corners a little more than my CO27's.
I ordered one i liked it so much!!!
B4Bandit is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
