Old 05-20-2007, 04:21 PM   #2281
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Has associated thought about the possibilty of aluminum rear hubs and steering knuckles?
Do they offer aluminum shims ? or will the xray shims be fine for raising up the links
wallstreet is offline   Reply With Quote
Old 05-20-2007, 04:33 PM   #2282
Rick Hohwart's Avatar
Originally Posted by DirtyDog3375
All shims and arm mounts are included in the kit. The only thing you may need to buy are:
* different thickness sway bars
* 1 degree rear hubs
* spool/oneway kit and pulley
* 0.5, 1.0, 2.0 and 3.0mm thickness alloy shims (for outer camber link changes - they do give you some spare 1.0 and 2.0mm shims, but to make finer changes you will need to buy some more....I have used the Tamiya ones)
Hope this helps.
- Leonard.
Also add a set of .5mm and 1mm axle shims to space the wheels out.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 05-20-2007, 05:30 PM   #2283
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
I dont know if they plan on doing some alumn parts or not but with the popularity of them on carpet I am sure they will look at the possibility now that the car is hitting the market.
Xray ones will work or AE 31286 is an assortment of blue alumn washer's for this.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 05-20-2007, 05:32 PM   #2284
wallstreet's Avatar
Thanks for all the info from both Rick and Eric
Good Luck to all AE drivers at the Reedy
Old 05-20-2007, 06:06 PM   #2285
B4Bandit's Avatar
Originally Posted by EAMotorsports
No it actually comes with Red and coppers. Its kinda in between an asphalt and carpet setup on the springs.
EA
Thanks for the heads up!!
I'll need to order some extra silvers.
B4Bandit is offline   Reply With Quote
Old 05-20-2007, 06:28 PM   #2286
dbmartin's Avatar
Is there a list of the part numbers listed online anywhere.
I would like to order my kit thru my lhs and order the spares.-
mainly
front/rear arms
front/rear belt
front 2/4 degree carriers
rear 1 degree carrier
spool
axles
dogbones
springs, is it safe to assume they have not changed?
itf chassis/top deck
sway bars
if anyone has these part numbers, I would appreciate it.
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 05-20-2007, 06:31 PM   #2287
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Instruction manual is very good. Pictures are good and words are easy to read and follow along.
There were words in there??!!
Ran the car today just to get everything loosened up and tested for proper alignment, electronics check, etc before going to the Reedy race. Finished the last 20% sitting track side but got to run none the less and everything was great. Ran a diff in the front just to get on the track, but even with it the car was very nice on the track.
Asphalt racers, make sure to buy a shock piston kit, as the kit comes with #3's, and many set-up sheets will probably include #2 pistons.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 05-20-2007, 06:37 PM   #2288
Team EAM
front/rear arms- Front 31205 Rear 31206
front/rear belt- Front 31187 Rear 31188
front 2/4 degree carriers- 2 degree 31211 4 degree 31212 6 degree 31213
rear 1 degree carrier- .5 degree 31219 1 degree 31220
spool- 31179 Spool kit
axles- Stub axle 31231
dogbones- CVA Bone 31232
springs, is it safe to assume they have not changed? Not changed
itf chassis/top deck- Chassi 31140 Top deck 31141
sway bars- 1.75mm 31263
EA
Contact Us
Old 05-20-2007, 07:09 PM   #2289
dbmartin's Avatar
EA
Thanks Eric,
And Go Gators!
Old 05-20-2007, 07:11 PM   #2290
If you guy's don't mind. Can someone post the associated spring pound rates. thanks
Juan Aveytia is offline   Reply With Quote
Old 05-20-2007, 07:12 PM   #2291
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
How about for the rear hub camber link washers? Axle spacers that Rick listed?
Thanks in advance.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-20-2007, 07:21 PM   #2292
Super Moderator
Kraig's Avatar
3941 TC FT Green Spring, 12.0 lbs.
3942 TC FT Silver Spring, 14.5 lbs.
3943 TC FT Blue Spring, 17.0 lbs.
3944 TC FT Gold Spring, 19.5 lbs.
3945 TC FT Red Spring, 22.0 lbs.
3946 TC FT Copper Spring, 25.0 lbs.
3952 TC FT Purple Spring, 30.0 lbs.
3953 TC FT Yellow Spring, 35.0 lbs.
3954 TC FT White Spring, 40.0 lbs
Old 05-20-2007, 07:23 PM   #2293
tc3 racer sc's Avatar
you went to durham brandon
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 05-20-2007, 07:45 PM   #2294
Team EAM
Thanks in advance.
The camber link washers are 31286. Its an assortment of blue washers 1-3mm. AE doesnt make wheel hex washers that I know of. Tamiya and HPI are the only ones.
EA
Contact Us
Old 05-20-2007, 08:30 PM   #2295
Mr. McGoo's Avatar
Thanks in advance.
PW just sent me some trick spacers that come in all sorts of widths - they aren't schumacher - i already cut off the name brand of the tag, so i am not sure the brand, but i will post tomorrow when i find out - they are great!
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
