Old 05-02-2007, 02:09 AM   #2071
sosidge's Avatar
Originally Posted by JuhoL
MR JOLLY: My board is just 10mm carbon fiber, Craigs board looks nicer and is a lot lighter too.
10mm! Must cost more than a whole TC5!!!
Old 05-02-2007, 04:53 AM   #2072
acyrier's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
Originally Posted by i am cornholio
whats with the ackerman mod on the steering blocks????
I 2nd that question..and as far as the little (waht looks like) CF, looks like the steering blocks are different all together.
http://data4.blog.de/media/895/1472895_7b1d8c2bca_l.jpg
compared to:
http://data1.blog.de/media/003/1424003_7e7a917c26_o.jpg
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 05-02-2007, 05:05 AM   #2073
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The first photo that you posted is the original TC4 steering knuckles. They had the extensions made to simulate the different ackerman positions. The second photo is the production pieces that are the result of the testing.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-02-2007, 05:15 AM   #2074
JuhoL's Avatar
compared to:
The steering blocks on my car are the TC4 blocks. The graphite parts help move the holes to where they are on the production parts, which you can see on Craigs car. Like I mentioned before we didnt have enough of the production parts yet so some of us used the prototype parts. The geometry on the parts is the same, they just look a bit different.
JuhoL is offline   Reply With Quote
Old 05-02-2007, 05:17 AM   #2075
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Juho what effect is had when you run the outside hole on the steering block as both yourself and craig did at this race. I have never tried the outside hole. Is it something you guys run normaly with rubber tires ?
wallstreet is offline   Reply With Quote
Old 05-02-2007, 06:49 AM   #2076
sliprip's Avatar
Originally Posted by sliprip
Juho...Why the o-rings under the rear screws for the top-deck; more flex or tweak issue?
@Juho May have been missed
sliprip is offline   Reply With Quote
Old 05-02-2007, 07:17 AM   #2077
JuhoL's Avatar
wallstreet: The outside hole gives less ackermann. I normally run with very little ackermann. Its the same effect as moving the inside ballstud forward. It normally makes your car more aggressive and gives you more steering.
sliprip: The O-rings are for more flex.
Old 05-02-2007, 07:51 AM   #2078
wallstreet's Avatar
juho in talking with paul lemieux at a race at his home track right before he left for the lrp masters he said the traction we were racing on was twice as high as it would be at the lrp race and that was the reason he didnt run cause any type of setup testing wouldnt be worth it cause the track at masters would be much lower. Now the question i have is would running the outside hole be way to much of an agressive change for here in the states if even what we think is low traction is really high traction for you guys.
Sorry for all the questions just trying to learn some stuff.
Old 05-02-2007, 08:22 AM   #2079
Originally Posted by MR JOLLY
craig got he`s done by Fibrelyte in the UK
pure honeycomb Carbon board
main reason for craig was weight when flying out to meets
Juho might have the same not sure
I contacted Fibre Lyte because I really wanted to get one.....120-160.
It's carbon fibre laminated onto foam core.
I'm not so keen on them now
Andrew Twigger is offline   Reply With Quote
Old 05-02-2007, 08:30 AM   #2080
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Wallstreet- I don't think Juho has ever raced with the high traction over here on rubber tires before, I think just foam. If you are referring to the ackerman specifically on the TC5, it should still be OK on rubber tires here. I am pretty sure I used the outside hole at the snowbirds in the rubber tire class. If yu feel like it makes the car to twichy and aggressive, use the inside hole on the rear A arm to smooth it back out and hook the car up. I was so amazed how one change like that made the car like night and day. Changing shock location on the arm made worlds of difference when compared to changing one hole on the tower.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 05-02-2007, 08:38 AM   #2081
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Here is one that is a little cheaper than that. http://www.robotmarketplace.com/mark...rbonfiber.html
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 05-02-2007, 10:03 AM   #2082
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Craig did say it was expensive ,but didn`t metioned any price
looks swish though
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 05-02-2007, 10:13 AM   #2083
MR JOLLY's Avatar
EA
the 11x16 inch looks promising for $125.00
my McMoney board is 12x18 inch
custom made 12x12 is $100.00 very nice price
Old 05-02-2007, 10:32 AM   #2084
MR JOLLY's Avatar
CML have said (been told by AE) mid -end on May for delivery in UK
300.00 smacker roons (hope fully it won`t come with RP30 pre glue's either
Old 05-02-2007, 10:33 AM   #2085
I was looking at those kind of sizes myself.
I'm not sure if it's just the picture they have on the website, or whether that is an actual product example, but are we right in assuming the edges wouldn't look like that? As that wouldn't look uber cool on anyone's pit table!
I managed to bow my 12mm thick plexi glass set up board hence looking at 'stiffer' alternatives! Well it certainly tells me my chassis is tweaked alright
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
