Old 02-08-2007, 09:04 PM   #1651
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Originally Posted by bretzkej
I just ordered mine from towerhobbies.com $349 - $30 coupon...
$319 for a new ride. I cant wait
That is a very good price.
Looking at the results from day 1 it looks like Craig has the car in 4th for 19 turn and 9th in mod. Looking at the lap times, it seems like everyone and I mean everyone is right there no matter what car they are driving. It just seems like 1 or 2 small bobbles will put you in towards the back of the B.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-08-2007, 10:53 PM   #1652
51
51's Avatar
That's about right. All the guys are right on pace...it's all about putting in a run. We have Drescher, Levanen, Hohwart, Henderson, Myrberg and Desrosiers running the car in TC Mod and 19T. Bob is the only one running it in Stock Foam and Brandon Melton is running it in 19T Rubber and Stock Rubber.
We've had some bad luck overall with cars flying into ours and causing wrecks combined with Joel getting hit at the end of the straight-a-way by a marshal jumping across the track. All in all the guys are running very well, but it's a tough, tight field. We'll have to see how things play out over the next few days. You can keep up on www.snowbirdnationals.com
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 02-09-2007, 12:50 AM   #1653
RCknight's Avatar
Default The hinge pin screws are on the inside of the bulkheads?
$20 bucks says the hinge pin blocks with break like eggs. It looks like a flush nut. It's hard to see, but there's a lot of stress on the hinge pin blocks. I still see no reason to buy one when you can get muti-flex design and better part material. I question the arm strength as well. Way to force feed your customers.
RCknight is offline   Reply With Quote
Old 02-09-2007, 02:18 AM   #1654
Regional Moderator
FroBoy's Avatar
blah blah blah
Team Losi Racing, Spektrum, Dynamite, Thunder Power, HobbyTown USA Hobbyplex
Proud member of the Scale Hobby Interest Team!
www.hobbyplexraceway.com
FroBoy is offline   Reply With Quote
Old 02-09-2007, 04:04 AM   #1655
Being a religious person I am sure you know the expression...
If you don't have something nice to say don't say anything at all...
This is not a tool on the TC5 thread!!!
By the way... I will take your bet!!!
AETC5 is offline   Reply With Quote
Old 02-09-2007, 06:19 AM   #1656
Kevin Boyle's Avatar
Thanks Brent,
We alll aappreciate the update on how th team is doing at the snowbirds. Tell the boyz to hang in there... The true AE fans are pulling for them.
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 02-09-2007, 06:35 AM   #1657
I am a Christian and I find it disappointing when I see some one that calls them sell a Christian and is obviously trying to preach to others behave in a way that makes the very people he is trying to save think less of him and his faith.
If you are going to post foolish post that you have no true knowledge about becyase you have not personally run the car please change your avatar and your signature.
FYI, I know a few of Xray's top Factory drivers and the chassis they run have the mulit-flex slots ommitted. They say all it does is make the car easier to tweak if you hit somthing. Thats the facts from 2 Xray Pro Mod A-Main driver I have known for years.
Carbuncle is offline   Reply With Quote
Old 02-09-2007, 06:37 AM   #1658
Patriiick's Avatar
Can you please go troll some other forum, like say, the Xray or Losi forum ?
Patriiick is offline   Reply With Quote
Old 02-09-2007, 06:48 AM   #1659
Lèche boules.
vision6789 is offline   Reply With Quote
Old 02-09-2007, 07:33 AM   #1660
Anders Myrberg's Avatar
Hmmmm............
Anders Myrberg is offline   Reply With Quote
Old 02-09-2007, 11:12 AM   #1661
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
TC5's R ON TOWER $349.99
Jim S is offline   Reply With Quote
Old 02-09-2007, 11:22 AM   #1662
Jim S's Avatar
FEATURES: Chassis: Double deck 1/8" (2.5mm) thick woven carbon fiber with blue
aluminum bulkheads for very rigid chassis assembly allowing easy
tweaks for high grip carpet racing or low traction parking lot
racing and all conditions in between
Drive: Four wheel dual belt
Motor Mount: Machined blue aluminum with integrated heat sink
Ball Bearings: Full set of 20
Shocks: Four VCS2 oil-filled with coil-over springs, silicone shock
bladders and hard anodized threaded bodies
Shock Towers: 0.12" (3mm) thick woven carbon fiber
Carbon Fiber: Front and rear shock towers
battery strap, steering rack, and bellcranks
Camber Link Mounts: Blue anodized aluminum
Top Deck Standoffs: Blue anodized aluminum
Arm Mounts: Blue anodized aluminum
Hex Drive: 12mm, clamping, blue anodizied aluminum
Main Gear: Kimbrough -- tooth, 48 pitch
Gearbox: Closed front and rear
Differentials: Ball differential in the front and rear, composite
with blue aluminum outdrive saver rings
CVDs:
Bumpers: Foam front
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
above
Steering: Ball bearing supported, mono-bellcrank with integrated
adjustable servo saver
Ackerman: Adjustable, Ackerman describes the effect of the inner
front wheel turning faster than the outer front wheel during turns
Sway Bar: Front and rear
Battery Mount:
INCLUDES: TC5 rolling chassis with oil-filled threaded aluminum shocks,
Carbon fiber chassis, shock towers, blue anodized
parts, carbon fiber parts, blue screws, 20 bearings,
Associated logo decal sheet, --T 48 pitch Kimbrough spur gear,
titanium blue anodized turnbuckles, illustrated manual and
complete parts breakdown
REQUIRES: Radio: 2-channel
Servo: 1-standard size
Motor: 540 size stock or modified
ESC: That can handle the selected motor
Battery: 6 cell side-by-side construction
Tires: Touring car tires
Wheels: Wheels that are the same width as the selected tires
Charger: AC/DC timed or peak for 6-cell battery
Body: 190mm touring car body
Pinion: Based on your motor selection
Misc. Items: Building and track equipment
SPECS: VEHICLE-
Length:
Rear Track:
Front Track:
Weight:
Wheelbase:
Internal Gear Ratio:
COMMENTS: For Replacement Ball Bearings use:
Qty. Size Location Qty. Bearing Set
Woven Carbon Fiber Parts
Lower chassis
Top deck, 2.5mm
2.5mm thick woven carbon fiber spine
3.0mm thick woven carbon fiber shock towers
Carbon Parts
Antenna mount
Front and rear arms
Servo mounts
Steering block and hub carriers
Aluminum Parts-all blue in color
Motor bulkhead
Camber link spacer, camber link (left side)
Camber link spacer, camber link (right side)
Standoffs
Clamping hex drives
Aluminum arm mount (Triangle)
Aluminum arm mount (Circle)
Aluminum arm mount (Square)
Aluminum arm mount (X-2.5)
Wheel nuts
For the stock 72 tooth spur gear the following are suggestions for a starting
pinion gear: 24-degree stock (torque based) 28 tooth pinion
24-degree stock (rpm based) 27 tooth pinion
19 turn spec 30 tooth pinion
12 turn (big track) 25 tooth pinion
12 turn modified 24 tooth pinion
11 turn modified 22 tooth pinion
10 turn modified 21 tooth pinion
9 turn modified 20 tooth pinion
8 turn modified 19 tooth pinion
Old 02-09-2007, 11:32 AM   #1663
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Since when is 1/8" 2.5mm? Assuming thats a typo...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 02-09-2007, 02:18 PM   #1664
B4Bandit's Avatar
Go AE Team at the Snowbirds!!!!
B4Bandit is offline   Reply With Quote
Old 02-09-2007, 02:28 PM   #1665
syndr0me's Avatar
Trader Rating: 32 (100%+)
If that price is right, this is going to be a very competitively priced kit when it's all said on done.
syndr0me is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
