new t2 xray chassis tweak
what can i do about this chassis is badly tweaked left front right back wheels are light the others are heavy , ?
step on the two shock towers while on a flat surface and tighten the top deck down: or try out a BMI kit >plug< :nod:
take your tires off make sure there is nothing on the bottom of your chassis
place your car on a flat surface like a tweak board or granite or glass loosen all your top deck screws and your car SHOULD go flat if it doesnt make sure and loosen all the screws in your car slowly going thru and tightening everyhitn gback down while leaving your top deck loose your car should go flat once its flat softly push down on the shock towers to hold the car flat and diagonally tighten your top deck screws when all said and done your top deck should be tithgt and when you put your car on a flat surface it should be flat |
Would this method work for the fk04 as well?
It would work on any chassis.
i dont know i did that like 5 times , even guys at the track put it on the tweak station and said it was way off , for somereason the right rear and left front are really light compared to other corner ? droop is set 5-4 , ride hieght is 5mm ? any ideas ? was thinking of a new top plate , pickels crc or bmi ?
Did you check shock length?
yep shocks are good , i get a quick right turn spin out even fliped car over today , and the left turn is wide , controler is set perfect , i mean how many times do you have to undo the top deck after a while the crews will strip , any other ideas ?
I'm sure you have this, but just checking, you dont have the bolt in the motor mount w/out the 2mm spacer, do you?
i have the pan heads in the motor without shims , but if your talking about the bottom screw that goes in to the bulkhead , i put a washer in there 2mm but whats the point of that anyway ?
Just if you didnt have that spacer, it could cause some really weird stuff... the top deck isnt on upside down, is it?
Make sure your bulkheads are square to each other. If your belts don't run true,then something is wrong with the placement with the bulkheads.
Takes some playing with but you will get it. :spidey: |
what do you mean run true , the rear belt rides to the right , top deck , i dont know how to tll if its up or down , i downloaded a anti teak method rfrom xray im going to try , ill let you guys know , thanks
On the top deck... the insert for the steering post bearing is offset to the right. If you have it to the left (deck upside down) by mistake it will induce a tweak into the car.
My biggest tweak problem seemed to be from the front shock tower. Loosen everything as mentioned above AND the shock towers. Proceed as above and tighten the shock towers last - while still pushing down on them. Worked for me. Good luck!
