Old 03-21-2006, 09:55 PM   #1
Send a message via AIM to benroc
Default peak detect
can somone explain this real quick , im using 5mv for the ib cells 3800 and there getting pretty hot at the end , im using ice charger , at 6 amp charge and there almost to hot to touch ?
benroc is offline   Reply With Quote
Old 03-21-2006, 10:04 PM   #2
XrayFK's Avatar
Go down to 2 or 3. The cells should peak at around 125.
XrayFK is offline   Reply With Quote
Old 03-21-2006, 10:09 PM   #3
loopedeloop's Avatar
You need to measure the temp at peak, should be in the 125F degree area.
If its higher Than 130F lower the threshold to .03.
Or the safer option start at the lowest setting your charger will accept and temp it at peak. If lower than 125F slowly raise the threshold until they are peaking at the correct temperature.
Exessive heat will kill your batts quicker than anything
loopedeloop is offline   Reply With Quote
F/T Dynamite Vision Peak 2 AC/DC Auto Peak Detection Charger InsaneRC R/C Items: For Sale/Trade 1 06-10-2008 04:04 PM
Peak Detect battery charger for Nitro Cars Helix70 Nitro On-Road 1 04-03-2006 09:17 AM
Turbomatcher Peak Detect Volts gc2005 Electric On-Road 5 05-21-2005 08:52 AM
WTB ProTrak - Temperature detect Module kumpol R/C Items: Wanted to Buy 1 01-19-2005 01:01 PM
Pro Trak Version 6 with TEMP detect module and heat sensor on heatsink bruisedwillis Electric On-Road 2 02-16-2003 05:26 AM
SEO by vBSEO 3.5.0
