New Tamiya Chassis TC-01 >
Like Tree778Likes
    Hide Wikipost
Old 12-05-2020, 09:50 PM   -   Wikipost
R/C Tech ForumsThread Wiki: New Tamiya Chassis TC-01
Last edit by: RCBuddha
INSTRUCTION MANUALS:
Vehicle instruction manual: https://cdn.simba-dickie-group.de/do...2-car-tc01.pdf
Formula E body instruction manual: https://cdn.simba-dickie-group.de/do...e-gen2-car.pdf
HOPUPS:
DRIVE TRAIN:
• Universal Prop shaft (TC01): #54975
• Double Cardon Prop Shaft (TC01): #54961
• Aluminum spur gear holder: #54903
• Universal shafts: #54515
• Clamp hex hub: #53570 or #53823
• Double cardan shaft: #42360
• Double cardan joints (TRF): #42216 (set) & #42239 (42mm shaft)
• Different Aluminum Drive Cup: #54543
• Steel Bevel Differential Gears: #54540
• Gear Differential Steel Cross Shaft: #54533
BEARINGS (in MM):
• 3x6x2.5: x2
• 9x5x3: x1
• 9x5 (flanged): x1
• 5x8x2.5: x12
• 5x10x4: x10
• 5x10x3: x2
• 10x15x4: x4
SCREWS:
• 3x5mm Titanium Hex Head Screws x4
• 3x6mm Titanium Hex Head Screws x6
• 3x8mm Titanium Hex Head Screws x18
• 3x10mm Titanium Hex Head Screws x13
• 3x12mm Titanium Hex Head Screws x12
• 3x6mm Titanium Hex Head Countersunk Screws x5
• 3x8mm Titanium Hex Head Countersunk Screws x10
• 3x10mm Titanium Hex Head Countersunk Screws x8
SUSPENSION:
• Suspension arm mounts (rear skid angle): #54787
• Supension arm mounts: #54760
• Stabilizers: #54956
• Aluminum rocker arms: #54955
• TRF big bore shocks: #42354
• TRF works shocks: #84317
• TRF Special shocks: #42102
• Carbon rear crossmember: #54783
• Carbon front crossmember: #54782
• Low friction suspension balls: #54747
• Titanium Coated suspension shaft: #53581
• Flourine supension balls: #53709
• Titanium Coated Shock Shaft: #54043
• Aluminum shock extenders: #54960
WTCC's adjustable suspension Conversion:
Parts needed:
• 3x23mm turnbuckles (x8)
• Yokomo #BM-206
• Awesomatix #P18 AND P19
• TRF 420 front hubs
DIFFERENTIALS:
• One way diff: #54521
• Spool: #54592
• Ball diff: #54522
TURNBUCKLES:
• Front Toe 3x18mm: #54247
• Rear Toe 3x32mm: #54249
• Steering Link 3x42mm:#54250
• Open Face Ball Ends: #54868
MISCELLANEOUS:
• Titanium Screw Set: #47449
• Servo mount screws: #54862
• POM Spacers: #54855
• Carbon front stiffeners: #54962
• Aluminum steering arms: #54958
• Aluminum steering bridge: #54957
Print Wikipost
Old 07-11-2021, 07:50 AM
  #736
Originally Posted by Dan
Hah, would have been all the more sweeter rallying with the Formula E body.
ic-racer is offline
Old 07-14-2021, 08:15 AM
  #737
Anyone have a good setup with the Formula E body, or been able to get Satoshi’s setup sheet translated?
I’m still trying to find rear grip and am struggling, especially in high speed sweepers. The car loses the rear end mid/late into the corner and I’ve gone ass-end into the wall quite a few times. I was losing upwards of a second a lap because I couldn’t hold through the high speed sweepers this last week, and we’re running the same layout for our regional TCS in a week and a half.
JoshuaRC10 is offline
Old 07-14-2021, 08:22 AM
  #738
simple's Avatar
If you haven't already, consider this....
simple is offline
Old 07-14-2021, 10:27 AM
  #739
ah, I forgot to test that. I’ll give it a shot and see if removing it helps.
Old 07-18-2021, 11:36 PM
  #740
GT CRUSING's Avatar
Default TCS TC-01 Car Setup
After seeing this car not grow much in popularity due to its extremely dificult nature of tunning causing massive oversteer, I have decided to reveal my Asphalt TCS Car Setup in it's entirety to encourace more people to get this car going from the get go. I have sadly seen too many get it and then sell it for not being able to tune it correctly. I was also dissapointed that the only other car setup online was not in english, so I have made sure to carefully detail everything in clear english for easy reading. Anyhow, cheers and see yall at the track!
GT CRUSING is offline
Old 07-19-2021, 07:18 AM
  #741
thank you!
how are you adjusting rear camber? I haven’t figured out how to make an adjustment without causing other problems.
Old 07-19-2021, 01:54 PM
  #742
GT CRUSING's Avatar
thank you!
Adjusting the suspension in this car is Caster, then Camber, then toe angle and then Ride Height/Droop. Anytime you change caster, camber or toe, you must essentially redo everything
Old 07-19-2021, 01:57 PM
  #743
good to know
but practically speaking, how is camber adjusted?
Old 07-19-2021, 02:20 PM
  #744
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Spacing out the lower arm further. You'll want adjustable turnbuckles for the front and rear hubs. I've got a set for the rear to dial in -3 degrees toe.
JoshuaRC10 likes this.
Dan is offline
Old 07-19-2021, 02:39 PM
  #745
got it. that makes sense. i've got adjustable turnbuckles on the rear now but got it in my head that i wouldn't be able to adjust camber with shims like that without screwing everything else up... but i hadn't actually tested it since putting on the adjustable turnbuckles.
i'm also curious about the optional suspension mounts (specifically part 54787)... is that action emulated by shimming the stock mounts and the only advantage to the alu mounts is the more secure attachments and smoother action?
thanks!
Old 07-19-2021, 04:26 PM
  #746
GT CRUSING's Avatar
thanks!
The aluminum mounts only offers more caster/ride height adjustments and more fluid suspension movement (as the stock plastic ones will turn egg shaped after prolonged use and hard crashes, thus jamming movement). Note, they are a few grams heavier than the stock plastic ones, but for sure are worth it
Old 07-20-2021, 11:48 AM
  #747
Other than with the optional suspension mounts (ordered but won’t get here in time for TCS) is there a way to reduce camber up front beyond removing the shims?
I've removed shims but it’s still ~2deg camber
Old 07-20-2021, 06:52 PM
  #748
GT CRUSING's Avatar
Nope, the plastic bits are bigger and you cant dremel them out per TCS Rules
Old 07-21-2021, 09:45 AM
  #749
i'll just have to work with what i have unless my order from tamiya gets here in record time.
Old 07-24-2021, 09:33 PM
  #750
GT CRUSING's Avatar
Default Propeller Shaft Comparisons
Here’s an interesting bit on the center propeller shafts weight comparison
The stock shaft is 11.2 grams $
The single cardan is 11.6 grams $$
The double cardan is 11.6 grams $$$
With the double cardan shaft being only 20$ more, its kinda pointless to get the single cardan as its the exact same weight as a double and only the double allows you to remove/install the motor much easier
