NEW SERPENT X20 FWD. >
Like Tree11Likes
Old 04-17-2020, 03:27 AM
tony gray's Avatar
Default NEW SERPENT X20 FWD.
tony gray is offline
Old 04-17-2020, 06:12 AM
Wow, more exciting than expected... more weight in the front end than many of the new fronties.
DavidNERODease is offline
Old 04-17-2020, 07:41 AM
Default Battery Positions
MatsNorway likes this.
Old 04-17-2020, 07:55 AM
OSherman's Avatar
This is a very interesting bit of kit..
OSherman is offline
Old 04-17-2020, 08:23 AM
This might be the one FF that has something for the AMX.
Old 04-17-2020, 08:40 AM
If the aluminum chassis kit comes with the hex hole/weight drilled system shown in the manual then I might not be able to resist. Serpent is killing it with this release.
Old 04-17-2020, 09:01 AM
The entire steering system is mounted solely to the motor mount - very nice.
Old 04-17-2020, 09:47 AM
OSherman's Avatar
the more i look at it, the more i like it.. very different approach overall. another nice addition to the field. looking forward to seeing some in real life..
OSherman is offline
Old 04-17-2020, 10:05 AM
SteveM's Avatar
Trader Rating: 165 (100%+)
Not a fan of the pivot ball suspension. :-(
SteveM is online now
Old 04-17-2020, 10:12 AM
I had/have zero problems with pivot ball suspension on my Project 4x Evo (hubs) I really like it actually because I can adjust play. When used on the inner pivot of suspension arms, it's far lighter than conventional hinge pin style - improves the polar moments on the car and that's what it's all about these days.
Old 04-17-2020, 10:45 AM
OSherman's Avatar
imo no car is perfect.. there are a couple things on my awesomatixA800FX that i would like to see 'changed'... but overall the car is awesome.
that being said, not a fan of the pivotable suspension either.. be still, im sure i could get it to work wonders.
OSherman is offline
Old 04-17-2020, 04:17 PM
Airwave's Avatar
Not really the same, because lowers arms have pivot balls at the two extremities on X20. And you can't setup the play on the inside end :-(
Airwave is offline
Old 04-17-2020, 05:05 PM
I know and that would be awesome eh.
Old 04-17-2020, 06:30 PM
The inside play was never really a problem for my X20 though, the upper camber arm pretty much restricted it. Probably one of the better cars in terms of play
herrokero is offline
Old 04-17-2020, 08:18 PM
delete
Bry195 is offline
