Old 03-18-2006, 10:22 AM   #1
Sryder7's Avatar
Default jaco replacing wrecked tires?
i've hear a couple things about jaco replacing cracked rims and even chunked tires at some tracks. I know that the tires are 100% garantied not to come unglued, but is the rest of this at all true or just some crap that people make up? if it's true, how do i get my tires replaced? i got about 10 cracked rims and 20 chunked tires
Sryder7 is offline   Reply With Quote
Old 03-18-2006, 04:42 PM   #2
Send a message via AIM to R/C Anonymous
They only replace them if they come unglued meaning that the tires will NOT be ripped away from the rim and the rim will be white with no foam residue on it.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-18-2006, 08:48 PM   #3
Well i have had a couple of cracked rims before but there is nothing to replace rims other tyhan getting a new set. And if you buy 1 set of the same hardnest of your chunked tires you can by some glue and cut out a chunk of the new tires and glue it on the old one. Make sure that the peice you glue is bigger than the tire. Then you just true the tire doen couple of mm and your done. Then you can do this over and over again.
Simon A is offline   Reply With Quote
Old 03-18-2006, 09:21 PM   #4
The way I understand it is this.....
Chunked tires come from hitting things like lane dividers or other cars.
It would be like asking GM to replace your bent fender after an accident!
John Warner is offline   Reply With Quote
Old 03-18-2006, 09:34 PM   #5
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Awhile back a friend of mine bought a set and they cracked on the first run. He sent them to Jaco, about a month later he got a new set.
I never will buy Jaco foams agian, I only use them with my T2 because they came with it...
Now Im off to buy some TRC's.
Michael Barch is offline   Reply With Quote
LRP QC2, KO VFS-1 C2, Airtronics 94357, RP Tires, Jaco Tires Randy Caster R/C Items: For Sale/Trade 2 10-20-2007 08:40 AM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 09:38 AM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 09:27 AM
HELP - need to get rubber tires off wrecked rims wdm80 Electric On-Road 7 12-22-2003 01:45 AM
Jaco NIB Tires mike_Webb R/C Items: For Sale/Trade 5 05-17-2003 12:00 PM
SEO by vBSEO 3.5.0
