Mid-Corner Hop - Technical Investigation
#46
If you don't have room on the shock shaft for an oring to gauge travel, clean the shaft and draw a line with a sharpie. Shock will wipe or wear off where it's traveling to.
#47
#50
Last Friday we ran the track anti-clockwise so grip was a bit down to begin with. However, even when the grip was up there was no issue with the bouncing
I was running the same setup as in the pics above (so slightly fimer rear than previously).
Hopefully this is a good sign but I will have to see what happens at the next meeting.
