jaco and parma foams? >
Old 12-11-2005, 09:45 PM
BiggAlz's Avatar
Default jaco and parma foams?
anyone notice a diference? i was just wondering if there double pink was the same as jaco etc...not the dual stage jacos....
BiggAlz is offline
Old 12-11-2005, 09:54 PM
I have run both companies tires and I have not found a difference in performance at my local track, I run Parma cyan and magenta and I have run Jaco dbl pink orange and dbl pink on the same car at the same track but on different race days and I say they are pretty close.
jeffb is offline
Old 12-11-2005, 10:02 PM
BiggAlz's Avatar
would the jaco double pinks match up the cyan front parmas? thats really why im bringing this up
BiggAlz is offline
Old 12-11-2005, 10:05 PM
I havn't tried mix and match of the companies but it would hurt for you to try the combo.
jeffb is offline
Old 12-11-2005, 10:09 PM
Speedo's Avatar
The Jaco double-pinks are rear tires (typically). Jaco dbl-pink-orange would be much closer to Parma cyans.
Speedo is offline
Old 12-11-2005, 10:34 PM
BiggAlz's Avatar
yeah...so double pink jaco in the back and cyan parma in the front....thats what im asking...
BiggAlz is offline
Old 12-11-2005, 10:39 PM
Yes, give that a try and let us know.
jeffb is offline
Old 12-11-2005, 10:40 PM
BiggAlz's Avatar
lol great, i was hopeing someone else tried it ....
BiggAlz is offline
Old 12-11-2005, 10:43 PM
LOL! Someone has to.
jeffb is offline
Old 12-11-2005, 11:10 PM
Trader Rating: 14 (100%+)
JeffB:
I think we should let BiggAlz try it.
since we switched to Parma we haven't felt the need to go back to Jaco's. the wraps kinda interest us but hearing mixed results on the tracks we race on so we'll stay with Parma.
double pinks = Magenta, double pink/orange = Cyan.
TimXLB is offline
Old 12-11-2005, 11:22 PM
Speedo's Avatar
I like Parma tires better, mostly because the fit better on the Xray car. They also come unglued much less than the Jacos in my experience.
Josh
Speedo is offline
Old 12-11-2005, 11:24 PM
eforer's Avatar
In terms of non-2 stage jacos vs parmas. the offsets of the jaco tires are different than the parmas. The jaco's will make your car about 2mm narrower, which is neither good nor bad, just different. You can widen out the car with widening shims, but that will give the car positive scrub radius, again not good or bad, just different. Also, althought the shore ratings are similar the grp rubber is a little different and the width of the hard "orange" outer shoulder is wider slightly on the jacos. Again just different, not an advantage or disadvantage. Obviously the 2-stage tires are not really comprable as they are a very different in construction.
eforer is offline
Old 12-12-2005, 07:29 AM
Speedo- what do you mean they fit better on your X-Ray car? Almost the entire X-Ray team uses JACO, so they must fit fine. Also, I am not aware of any gluing problems on our tires.
Jack Rimer is offline
Old 12-12-2005, 07:54 AM
Jack-
Can you run a double pink front and pink rear and how would it differ fromt a pink/orange front and lets say and double/pink or pink rear?
Is a double pink kind of like a double purple front just softer.
bigdog xxx-s is offline
Old 12-12-2005, 07:58 AM
BiggAlz's Avatar
i think he means when the edges peel and chunk
BiggAlz is offline
