Old 03-07-2006, 02:16 PM   #1
Pro Models's Avatar
Default GM EVO2 IFMAR Brushless
Have a look at the specs guys. I guess it should be one of the most powerfull on the market if we had to compare watt figures, although from what I learnt max figures aren't the way to go as a form of comparison.
Pro Models is offline   Reply With Quote
Old 03-07-2006, 06:01 PM   #2
hobbipro's Avatar
Trader Rating: 19 (100%+)
Very cool, looks like the ESC will accept Novak/Lrp sensored motors as well. (I'm assuming the little white plug in slot between the power wires is for those motors).If so,it should be legal here in the states. I'm glad to see all the top electronic manufactures moving the brushless ball along!
hobbipro is offline   Reply With Quote
Old 03-07-2006, 06:13 PM   #3
ttso's Avatar
I know no German but this is what BabelFish translated:
GM BRUSHLESS EVO 2 engines GM Racing states the RC Car brushless Technology. GM Racing uses thereby the already over 6 years long experience within the range of the Brushless engine and automatic controller technology. With the new BRUSHLESS EVO 2 engines is to be developed GM Racing successfully after the DMC regulation high-efficient and low-priced engines, which set new yardsticks in reliability and achievement. Extra thickness mehrfachwicklungen as well as an extremely low-loss Design without unnecessary conductive strips and temperature-firm neodymium magnet provide for achievements of clear over 270W. Thus the GM Racing reaches BRUSHLESS EVO 2 6T and 5,5T engines achievements and efficiencies, which are not for a long time reached by brush engines because of the heating. Without the expensive, shock and temperature-sensitive resounding sensors and unnecessary inlets of the sensors was done, in order to reach a clearly higher reliability. Nevertheless together with the GM GENIUS of 80 travel automatic controllers an automatic controller action was reached that from conventional automatic controllers for brush engines in nothing is inferior. The "slotted" Design of the stator ensures for a handling that corresponds to that of a conventional engine. The BRUSHLESS EVO2 IFMAR SPEC is equipped with sensors and has higher numbers of revolutions with fewer torques. Victory of Markus Mobers with the Graupner anniversary running. 5 of 10 A-Finalisten used that GM brushless system.
So unless BabelFish is wrong, it's sensorless brushless motor, so 100% not OEM by either LRP nor Novak, but probably by Graupner?
Very interesting indeed...
Btw, if you check Graupner's website.. wa.. 4.5T listed...
ttso is offline   Reply With Quote
Micros, Evo2 FOC, MX3, Brushless, 16x7v6 +more Altrodesigns R/C Items: For Sale/Trade 1 06-24-2006 05:14 PM
IFMAR Brushless rules e_lm_70 Electric On-Road 1 08-26-2005 07:58 AM
BRUSHLESS MOTORS Now Legal At ROAR Races & The IFMAR Worlds!!! STEALTH Electric On-Road 315 03-22-2005 03:09 PM
BRUSHLESS MOTORS Now Legal At ROAR Races & The IFMAR Worlds!!! STEALTH Electric Off-Road 3 03-17-2005 09:16 PM
Brushless Motors and ROAR / IFMAR??? black-knight Electric On-Road 20 12-17-2003 04:15 AM
SEO by vBSEO 3.5.0
