NEED HELP WITH A TWEEKED CHASSIS
I have a xray racer chassis that is tweaked from right rear to left front, I have adjusted ride height, changed springs, droop screws and unbolted the top plate to let it settle. but from there a little stumped. any advise would be greatly appreciated.
[email protected]
[email protected]
dont know about the racer but the 05 can suffer from tweak once the servo saver post gts bent. You might check that. Or try to eliminate the chassis as the problem by removing everything from it and seeing if it lays flat on a glass, marble or other perfectly flat surface.
