Old 03-04-2006, 04:48 PM   #1
GrandeGixxer's Avatar
Default 0-30 Mod
For those of you that sometimes forget to plug in the 0-30 when you put the battery in or for get to unplug it when you take the battery out, this mod is for you. What I did is buy a small lever switch from Radio Shack. I simply spliced the red wire in to the switch. I then mounted it with some servo tape so that when I drop the lever to make contact with the battery, it turns on the fan. It has worked out great so far.
GrandeGixxer is offline   Reply With Quote
Old 03-04-2006, 05:13 PM   #2
Trader Rating: 14 (100%+)
Great idea.
Phatkat is offline   Reply With Quote
SEO by vBSEO 3.5.0
