Old 03-04-2006, 05:55 AM   #1
IslandBwoy's Avatar
Default GTX Programming issue:
Do any of you guys have a GTX? Im just trying to program mines and everything runs well but after the programming is done:
if i give it about 30 percent throttle its all good. But once i pass that the motor will just run even after i let the throttle go !?!?!?!? Anyone had this issue? I've already reset everything on my transmitter and started over a few times. I dont know what the hell this could be a bout.
IslandBwoy is offline   Reply With Quote
Old 03-04-2006, 06:37 AM   #2
set the hipoint to 150 and brake to 100 then go through the setup again - if that doesn't work you may need factory help
DLM2005 is offline   Reply With Quote
Programming ESC peterchia41 Singapore R/C Racers 2 03-18-2008 05:13 AM
ESC programming ???? rcarmchl Radio and Electronics 1 03-15-2008 08:02 AM
CC BEC programming superlapS15 Radio and Electronics 0 02-07-2008 05:57 PM
GM SX-9 esc programming help rinkrat99 Electric On-Road 2 12-26-2004 01:16 AM
Programming a esc karter Electric On-Road 1 03-04-2004 09:24 PM
SEO by vBSEO 3.5.0
