Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-07-2009, 01:29 PM   #1231
A-Ko's Avatar
Send a message via AIM to A-Ko Send a message via Yahoo to A-Ko
Originally Posted by TonyK View Post
How are you guys maintaining the silver cans. I have one in a 1/12 scale and just want to maintain it properly. The motor seems pretty fast and I want to keep it that way.
Heat is an issue. If you have a temp gun that is very handy in seeing if you are over/under geared. Usually anything above 180-200 deg is too hot, around 160 deg is a good place to be. Also what fleet said about keeping it oiled and clean.
Jeffrey Stevens
Can Race, Will Travel
A-Ko is offline   Reply With Quote
Old 05-16-2009, 05:49 PM   #1232
so how does using fancy capacitors and/or shotcky diods play into the performance of these motors??
I notice the fastest guys are soldering those multi-shotcky diodes and way over sized capacitors to either their motors or the escs
mugler is offline   Reply With Quote
Old 05-16-2009, 07:40 PM   #1233
fleetmaster's Avatar
Location: XRAY LAND-where everything fits first time....
From what I understand, the diodes protect a forward/brake esc from back emf.
The caps only store a charge when you back off and discharge when you apply throttle again.
But really, why would you back off with a 540 ? That only slows you down.
At my local track, its W.O.T for 90% of the time or more.
**********XRAY T2R PRO = fast 'glass**********
*********M-05*********DX3-S / SPX / TRINITY DUO / NOVAK SS / INTELLECT.........
#1 CLUB W.E.R.C @ #1 Track W.H.R.C . Ph # 45 773 166.
fleetmaster is online now   Reply With Quote
Old 05-16-2009, 09:12 PM   #1234
niznai's Avatar
Fleetmaster is pretty close. Large capacitors on esc store a bit of charge that is used to top up the battery supply when accelerating hard and the battery is momentarily depleted. As one will notice this is not very likely with an esc incapable of delivering high enough currents to affect the battery output.
The Schottky diode is a drain for the reverse emf of your motor when braking especially but generally for improving the overall motor performance. The reason they use more Schottkies is because they can't find a big one that'll do the job (they do exist) but has the added advantage of lower capacitive impedance at higher frequencies (generated at higher motor rpm). Large Schottky diodes come in a TO capsule which is more difficult to solder to the motor too, because they look like a power transistor with three terminals that need to be paired correctly rather than a little cylinder with two wires sticking out.
If nobody told you this, don't ever use a Schottky with a reversible speedy because you will fry it instantly.
Up to you. Make sure you have the little 100nF capacitors on the motor too.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-20-2009, 01:09 AM   #1235
so i guess there will be some performance increase with the silver cans but not much.
Can the shotckies and the capacitors be used at the same time?
Old 05-20-2009, 01:26 AM   #1236
FK05 lover's Avatar
Trader Rating: 82 (100%+)
Yes
Bro-Kin Racing Group...Castlehill Raceway...
AUSWIDE Hobbies...
Xray T2 009...
FK05 lover is offline   Reply With Quote
Old 05-20-2009, 04:32 AM   #1237
rccardr's Avatar
Yes, you can.
However, in our testing of multiple speed controls using silver can motors we found no lap time improvement using any combination of additional/larger capacity diodes and caps beyond that required by the manufacturer.
Best way to get your motor to go faster is to use a faster motor.
Best way to reduce lap times is to drive better and use an efficient suspension setup that carries speed through the turns.
Jeff does make an excellent point about the temp gun- we've found that heat range is the most efficient way to determine gearing and setup efficiency.
I've never lost.
I've just been a little bit behind when time ran out...
rccardr is offline   Reply With Quote
Old 05-20-2009, 08:25 AM   #1238
Where does everyone check the temps? Most temp guns will not give a good reading on the can itself.
Granpa is offline   Reply With Quote
Old 05-20-2009, 08:28 AM   #1239
Core Creations's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Core Creations
I've always temped at the comm.
At the Omaha TCS this last weekend...all of the 13,500 rpm limit motors of ours never temped over 140 in mini...about 155-160 in GT3.
2009 Omaha TCS Mini Winner
2009 Mini EnduroChamps TRR
2008-2009 Memphis TCS MINI Winner FIAT Power!!
CORE CREATIONS CUSTOM PAINT
http://rctech.net/forum/showthread.php?t=121907
Core Creations is offline   Reply With Quote
Old 05-20-2009, 04:35 PM   #1240
Drifting101's Avatar
I check mine on the rear end bell
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-11-2009, 06:43 PM   #1241
hprt's Avatar
Are you measuring temps on the can/endplate or on the armature?
Cheers,
Scott W
KARZ.ca // CARCAR.ca
hprt is offline   Reply With Quote
Old 10-11-2009, 07:17 PM   #1242
Measure motor temp at the comm
Old 10-11-2009, 09:54 PM   #1243
A-Ko's Avatar
The com would be nice but usually the can could be a fair alternative.
With my fans and heatsinks usually I just do the can, although lately there has not been a need.
Jeffrey Stevens
Forum Jump
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 01:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 09:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 10:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 09:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 09:54 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
