Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-17-2006, 06:45 PM   #46
minimadman2003's Avatar
Trader Rating: 24 (100%+)
In general the 4-slot motors feel as though they have weaker magnets, thus more RPMs and less drag brake in the corners. They are good for drivers who can carry momentum through the corners, but I personally find they lack torque for those of us that drive more with throttle than finesse. I've had my best luck with 4-slots in Mini where you don't need torque. But there are plenty of 2-slot motors out there that can blow my doors off down the straight.
I don't believe the 4-slots are 23 turns as others have said, but they will sound as though they spin up faster with little or no load due to the weaker magnetic field. But then again, I've had dog 4-slot motors too. I think everyone is correct in saying you have to go through a lot of motors before you pick the cherries out and give them and your car a little TLC.
M01, M03R, M04L, M05 PRO,
TA05R, TA05-IFSR, TT-01 Senior Spec,
Midnight Pumpkin, Lunch Box, CC-01 Wrangler,
CR-01 Land Cruiser 40, TNX-PRO, SC10,
Crawler King, Slash, SCX10 "Fendy"
minimadman2003 is offline   Reply With Quote
Old 05-18-2006, 04:27 AM   #47
rccardr's Avatar
Correct, Bill. 4-slot motors have 27 turn arms and are fully legal, but were made in a land long ago and far away when they balanced the arms by hand one at a time and did a much better job. Since good arm balance is one of the primary reasons one Johnson motor will spin faster than another, statistically you have a better chance of getting high rpm with a 4-slot.
But, as you said, 4-slot motors also have weaker magnets and thus generally produce less torque, which is why I normally run a 4-slot in Mini and use a 2 slot in GT3. Having said that, my Mini race motor right now (and the fastest one I own) is a 2-slot, and I ran a 4-slot in GT3 in Memphis to a 2nd place finish. So it all depends.
Like Bill and Jeff said- you gotta buy a lot of motors and break 'em in to find the fast ones.
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
rccardr is offline   Reply With Quote
Old 05-18-2006, 07:37 AM   #48
nagatahawk's Avatar
I don't really have a for real dyno. I was using a APS motor dyno, running at 5 volts with no load. the numbers are what read out. and the figures are just to show the point of how I came up with a few more rpms and more amp draw, buy applying a little tuning. I continue the search into the black hole of silver can tuning.
I have a feeling these numbers are realistic as these motors properly tuned will turn in lap times at the Tamiya test tract as fast if not faster than stock motor times. and I saw them lap me several times at the Tamiya TCS finals.
BTW after breaking in the motor for 1 hour on the APS motor dyno Motor Break in Mode, the brushes appear to be almost fully seated. I will go out to tamiya next month for testing for the TCS qualifier in July. I will report if I can tell any real improvement in motor performance.
also I will test my best IB 3800s vs. my best 3300s to see if the weight will make that big a difference in performance. Last year the 3300's appear to be as good as my gp 3700s. probably because of the weigh saving over the minimal voltage increase.
Please continue to post up anything else that improves the motor.
nagatahawk is offline   Reply With Quote
Old 05-18-2006, 07:45 AM   #49
nagatahawk's Avatar
regarding the 2 slot vs. 4 slot, fyi at the Tamiya finals you have to purchase motors there,and the cans are marked. so any tuning tips other than buy a couple of dozen motors would be helpful.
I was threatening myself to move up to gt1 and gt2 rather than attempt to find the anwser to these motors, but finances will limit me this year. I hope my horsies come in this week end at the Preakness.
Old 05-18-2006, 07:35 PM   #50
The motors last year at the Nats were Johnson 2-slots, and they had some seriously HARD brushes. It took hours upon hours of water dipping at 3V to get them to seat.......or at least that's what I experienced.
This year I've read the hand-out motor for GT2 and Mini will be black can Sport Tuned Mabuchis, and my limited experience has found that they have much softer brushes that require minutes instead of hours to fully seat. Beyond that, I haven't a clue!
And before you get too excited about battery choices, don't forget that GT2 and Mini will also be required to run a SPEC battery purchased at the Nats.
Old 05-19-2006, 02:03 PM   #51
A-Ko's Avatar
Send a message via AIM to A-Ko Send a message via Yahoo to A-Ko
Originally Posted by Hebiki
jeff.. gonna share your secrets? i heard you had a land missile at the last TCS!
Secrets... who me ? ? ?
I think the Docs squared know more
Time, a slave motor dyno and breaking them in before running them on the track are what helps me get mabuchis going. . .
Jeffrey Stevens
Can Race, Will Travel
A-Ko is offline   Reply With Quote
Old 05-19-2006, 02:06 PM   #52
Hebiki's Avatar
heh..
ill pick your brain and his dont worry. i think the Hickmans will be out in at Fremont TCS in June.... i can ask there
Sponsored by:
REI | Coleman | Patagonia | The North Face | Camping World
http://video.about.com/camping/How-To-Build-a-Campfire.htm
Motto: A sniper who has a grassy knoll on lockdown.
Hebiki is offline   Reply With Quote
Old 05-19-2006, 02:10 PM   #53
A-Ko's Avatar
heh..
I better start saying ouch now..
Actually I will have to start looking into the Aug handout motors about now...
Jeffrey Stevens
Old 05-20-2006, 02:34 AM   #54
Originally Posted by TAMIYAMANUK
so its a good,worn in , clean motor then that the serect
Just advance the timing. That will definetly help you beat your frriend.
Juan Aveytia is offline   Reply With Quote
Old 05-20-2006, 07:41 AM   #55
Send a message via MSN to TAMIYAMANUK
and how do you do this on a silver can
TAMIYAMANUK is offline   Reply With Quote
Old 05-20-2006, 06:57 PM   #56
A-Ko's Avatar
you don't
Jeffrey Stevens
Old 05-26-2006, 06:18 PM   #57
kuanseng1981's Avatar
Default 30000 RPM Silver Can
Any1 here want to pay me for a 30,000 RPM, 2.5 amp @7.2 volts silver can.
It is not the Motor or the ESC, It's the Driving
kuanseng1981 is offline   Reply With Quote
Old 05-26-2006, 09:18 PM   #58
MK_Arbiter's Avatar
I have a brilliant while dumbass idea. Take a mod motor and sand off all the paint from the can. LOL I'm a stupid genius.
MK_Arbiter is offline   Reply With Quote
Old 05-27-2006, 12:23 AM   #59
loopedeloop's Avatar
loopedeloop is offline   Reply With Quote
Old 05-27-2006, 12:38 AM   #60
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
Originally Posted by rcnewb2004
your all bloody rc nerds and like rc cars more than girls you stupid virgin nerds!!
WHAT!!!!!!! you the bloody nerd!
!xray!
Got Xray? is offline   Reply With Quote
Forum Jump
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 01:44 PM
Silver Can (Mabuchi) Motor Tricks miller1990 Electric On-Road 1 03-06-2007 09:06 PM
Co27 motor tuning tips, hints, or tricks schmidt452 Electric Off-Road 16 11-08-2006 10:04 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 09:50 AM
Tips And Tricks rctc3 Electric On-Road 36 03-10-2002 09:54 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
