Old 02-25-2006, 09:52 PM   #1
aN4rK1's Avatar
Default M11 + Spektrum Questions
Hi guys. Iam looking at getting a M11 with spektrum but I havea few questions. Ive heard that the first set of spektrum modules have to be sent back for some kind of upgrade. Is this true? What model is it the SPM1003/SPM1000 or the SPM1200? And you had to do some mod to the spektrum module by drilling two holes or something to make it fit into the M8? Is this also true for the M11?
aN4rK1 is offline   Reply With Quote
Old 02-25-2006, 11:20 PM   #2
Xyvern's Avatar
You don't have to worry about the Spektrum module for M11 now, the problem has been solved long time ago just buy the module for M11 you are set to go.
Xyvern is offline   Reply With Quote
Old 02-26-2006, 05:24 AM   #3
stiltskin's Avatar
Trader Rating: 97 (100%+)
All of the newer versions have already been updated and the box says M8/M11. The M8 has 6 pins, the M11 has 8 pins. The Spektrum only uses 6, so the board on the Spektrum module had to be drilled/dremeled out to allow the extra 2 pins on the M11 to slide inside the Spektrum case.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-26-2006, 05:36 AM   #4
The_Stig's Avatar
You should be fine now. I've been using the M11/Spektrum setup since November and have nothing but great things to say about it.
The_Stig is offline   Reply With Quote
Old 02-26-2006, 05:54 AM   #5
Glowster21's Avatar
Trader Rating: 114 (100%+)
Not all of the M8/M11 modules have been updated with the re wired antenna. I got 1 on New Years Eve and it did not have the re routed antenna. It was 1 of the newer ones for the M11 too. Horizin was quick to turn it around for me though.
Glowster21 is offline   Reply With Quote
spektrum radio questions famous182 Radio and Electronics 2 07-18-2008 04:35 AM
Spektrum DX3.0 antenna mounting questions Miller_Time Radio and Electronics 3 01-12-2008 07:50 AM
Spektrum Questions for Futaba 3PKS Jason B Electric On-Road 5 06-05-2006 10:44 AM
Failsafe + Spektrum Questions aN4rK1 Nitro On-Road 3 04-25-2006 02:54 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 01:19 PM
SEO by vBSEO 3.5.0
