Gizmo Racing USA Genesis TC Kit
#76
#77
#78
#79
#80
It is actually the orientation of the scissor links not the camera angle.
From your photo - on the left the P01 is swept back and on the right the P01 is swept forward.
As opposed to both swept forward like the manual clip below.
More like this....
More like this....
#81
Ah i see Ive been running them like this for the last few gens gizmos without issue, if I get some free time ill switch it around. I didn't even think to try and make them the same, a bit of ignorance on my part. Thanks for the tip!
#83
Good luck at USIC. What setup are you starting with?
#84
#85
Not an owner, but definitely a curious admirer of the chassis. What is the advantage of an inboard mounted shock vs and outboard mounted shock?
#86
#87
I have seen belt wear like that before, basically the belt flaps up and down when in use and rubs on the lip of the pinion grub screw. Maybe tighten the front belt slightly to stop it slapping the pinion....
#89
ah! I see the optical illusion lol
