T.O.P. Racing "Scythe" 1/10 EP Touring Car
#212
Originally Posted by DZ
So I ran the car on the weekend on foams ashphalt at our Summer nationals warm up, car handled beautifully, I set TQ and the faster lap of the day in Stock
Here is my set up
2.5 US SPec chassis
FRONT
-Tamyia Shocks 3 hole 45 weight oil (used tamiya shocks so I could take advantage of longer xray springs
- Xray purple Springs 30 LB
-Shock postion standard
-2mm on uppper link longest link,
-1mm below blocks
-NO front arm sweep 0 degree bblock
-3mm in front of arms and 3mm behind arms
-No sway bars
-5mm ride height 2mm droop
-Akerman block all the way back
REAR
-Tamiya shocks 3 hole 45 weight
-Dark blue xray springs 25 LB
-Shock position one lower then standard
-.5mm on upper link longest link,
-1.5mm below blocks
-3 degree rear toe.
-2.5mm in front of arm
-2mm in front of rear hub
All alloy bits used.
mazda 6 body
40 rear foams all around
D/R 70 %
This set up is very agressive but holds so much corner speed.
Hope I get a good result this weekend at the actually event
Enjoy
Damien
Here is my set up
2.5 US SPec chassis
FRONT
-1mm below blocks
-No sway bars
REAR
-1.5mm below blocks
-3 degree rear toe.
mazda 6 body
D/R 70 %
Enjoy
Damien
Happy to report I won the Australia Summer nationals on the weekend running basicly the above setup, the car was awesome on Foams
I made a few more small changes during the weeknd
I went to 42rears on the front on the car,tire diameter I ran was 59mm
Also went to 35 weight oil on the front of the car.
Cheers
Damien
#213
excellent results from Damo and Dan over the weekend,
Damien Zarb, TQ and finished 1st overall in stock (using US spec chassis and foam tyres)
Dan Garcia, Q3 and finished third overall in stock (flexy car with rubber tyres)
Damo has proven that the car can work very well on foams,
#215
The rear hub carriers are HPI/Hotbodies, 0deg toe. The car has 3deg inboard toe-in with the standard suspension blocks (also HPI/Hotbodies parts). No Yokomo parts in the actual suspension components, just the shocks, diffs and driveshafts.
#220
Any build tips and advice for running the Scythe with foams on asphalt.
Just got our kits and the US spec chassis and top plate .Still have to get the ally bits .Would the ally bits make that much of a difference ???
#221
hi shiraz
is it the 2.5mm top deck you have , the std shape one?
jimmy
jimmy
#222
Hi all
Got another outing this weekend on carpet / vtec24. What pistons / oil should I be using? Not done alot of carpet racing before so have no idea if there are any do's and don'ts for carpet.
Got my new horse power as well (thanks Jimmy) and looking for at least a B final this time.
#223
Originally Posted by jimmy..maddison
hi shiraz
jimmy
jimmy
I have the top and bottom 2.5mm chassis plates.
#224
tony
look on muchmore website for my set ups with vtech tyres!
jimmy
jimmy
#225
Pistons
Hi Jimmy
Are the kit piston's 1.2mm?
Tony
Tony
