T.O.P. Racing "Scythe" 1/10 EP Touring Car >
Old 01-04-2007, 11:14 AM
  #166
MadBrushRacing's Avatar
Default upper bulk heads
Hi
Can someone tell me if the inner camber link on the top plastic bulkhead is the same height as the alloy one? Just wondering if I need to make any adjustment the spacers under the ball stud to make them the same height so the roll centre stays the same?
MadBrushRacing is offline
Old 01-04-2007, 11:36 AM
  #167
Ali Graham's Avatar
I belive they are the same
Ali Graham is offline
Old 01-04-2007, 05:29 PM
  #168
Hi !
Im running the Gold Standard Edition and a Red Full Options (including 2.5mm U.S. Spec Chassis + 2.5mm Topdeck). (Some Pictures soon of the Red Edition)
Im running my Standard Scythe in Viol, too .. like Patrick ... but the Standard Scythe is to flexy for this High Grip Carpet. I see he has all Alloy Parts, it's much stiffer
I think 2.5° Toe-Out at the Front Brakes with One-Way ... better to use 1,5° or 0° ... 0° on High Grip and 1,5° on Low Grip
Me and my Team want to test all Toe-Out Possibilities, soon
@ 3rd-dan
Some Pics of the Red Edition soon :P ... I driving the Gold and Red Edition in Standard Class. Next week, i'm not in Althengstett but my Teammates are there
@ MadBrushRacing
I think they have the same height... but i didn't check this exactly
Greetings from Germany
iZzy
#iZzy is offline
Old 01-05-2007, 09:03 AM
  #169
Patrick (HLR)'s Avatar
Hi Izzy,
My Car was really stable , no problems with too much steer , no grip rol and even the dots where no problem. Other people noticed too that my car was really stable too drive. And yes it's got almost all alu parts. The car was undesteered a lot with the stabi's while my xray T2 seems comfortable with the stabi's indoor.
I did have no time yet to train but i was thinking what the difference is between the 2.5 and 1.5 blocks in front. How will this influence the car behaviour ? Maybe stupid question but no mather what block you use you always bring the toe in setting to around 0.5 / 0 Degree with the steering turn buckles ?
Thanx in advance
Cheers
Patrick
Patrick (HLR) is offline
Old 01-05-2007, 11:01 AM
  #170
Ali Graham's Avatar
Hi Patrick
The 2.5 toe mount would be more likely to make your car want to grip roll. More outboard toe increases turn-in bite, but slows the rotation of your car. Indoors, 1.5-1 seems good on medium grip carpet.
Yes, always stick to those toe-in angles on the steering links, then you'll know what changes the suspension mounts make
Old 01-05-2007, 01:58 PM
  #171
Yes, Ali is right =)
2,5° inboard Toe-Out at Carpet Tracks seems to much. Viol Carpet is a High Grip Carpet and 2,5° will bite there. Try 1,5° or 0°...
But now, some Pics of my Scythe.
#iZzy is offline
Old 01-05-2007, 06:53 PM
  #172
Rod M's Avatar
Hi Izzy, the car looks great,
I recommend to use longer screws and self locking nuts to fit the top of the shocks to the shock tower,
Rod M is offline
Old 01-05-2007, 07:12 PM
  #173
Yeah, you're right
But i haven't longer Screws
Before the Scythe, i was driving Yokomo BD ... The BD uses longer Screws and self locking nuts.
Maybe i can order some Yokomo Screws .. =) ^^
#iZzy is offline
Old 01-07-2007, 10:26 AM
  #174
Default roll bars
Are the rollbars used the cyclone ones?
Izzy
How did you get to use wishbone spacers on your red car?
Old 01-07-2007, 10:28 AM
  #175
Izzy
Hi !
The Rollbars are "normal" T.O.P. Scythe 1.4mm Rollbars.
If you use the U.S. Spec Chassis, you need longer Hinge Pins, because the length from Susp. Mount to Susp. Mount is longer ... but so you can use Spacers
#iZzy is offline
Old 01-07-2007, 10:33 AM
  #176
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
very nice! when is that car going to be available in the U.S.?
Marcos.J is offline
Old 01-07-2007, 12:21 PM
  #177
razzor's Avatar
The red kit looks awesome !!!
I hope to have my kits by weekend.
Anyone have a asphalt/foam tyre setup that I can start from and any other tips would be welcome.
Hope to have the thicker chassis and braces too ,as we only race on asphalt with foam tyres ,rubber died years ago.i think only tamiya stock class runs rubber these days.
razzor is offline
Old 01-07-2007, 12:31 PM
  #178
GreaseMonkey's Avatar
It's been available in the US for some time. I think the original poster of this thread is the US distributor.
http://www.rckenon.com/
GreaseMonkey is offline
Old 01-07-2007, 08:44 PM
  #179
Rod M's Avatar
some of the cars that I have recieved recently have been packaged with the 1.6mm swaybar,
I believe that the cars will now come with 1.6mm in the standard kit instead of 1.4mm
Rod M is offline
Old 01-07-2007, 09:16 PM
  #180
Super Moderator
Marcos.J's Avatar
thanks
Marcos.J is offline
