T.O.P. Racing "Scythe" 1/10 EP Touring Car
#1517
How much rebound does you guys usually run for the TOP Scythe ?
So far i've only run zero rebound(which if im not mistaken means the shock shaft is fully extend out right?) and found that the car can have an aggressive/loose back end...
Would running some rebound(pushing the shock shaft slightly inside before putting the cap on) helps to reduce the loose back end?
I don't have problems with a loose end.
Witch version do you have? full allu?
#1519
My basic setup...
Camber : -1 deg
Toe : + 0.5deg /0 deg
Droop : Front 5mm
Rear 5mm
Ride height : front 5.5mm
rear 6.0mm
Diff: Front spool Rear ball diff
Springs standard kit...
The car is manageable to drive but I had to reduce the radio's D/R down to 40%... I would wana increase the D/R up to 50% but afraid the I would loose the back end during cornering...
#1520
wat is your rolcenter in front and at the rear?
How are your shocks placed and witch springs?
I will fill in a sheet with my setup and send you a link.
Is it for indoor or outdoor?
asphalt or carpet?
rubber or foam?
I dit use the plastick motor part also but i changed it to the ally version to get moore carner speed.
My steer is standing at 40 to 45%
doesn't need tho much steer.
also my exp is -70.
asphalt or carpet?
rubber or foam?
also my exp is -70.
#1521
asphalt or carpet?
rubber or foam?
also my exp is -70.
asphalt or carpet?
rubber or foam?
also my exp is -70.
Should I change the plastic motor pod base to the aluminum ones coz I have them with me... its just that I heard someone saying the plastic ones gave more flex....
What do you mean by rollcenter ??? Is it the suspension mount spacer? If so i'm using 1mm suspension mount spacer front and rear...
#1522
Trader Rating: 171 (100%+)
Canadianmeyhem YGPM
#1523
Im running outdoor asphalt/tarmac using rubber tyres... so basically using some rebound does no difference is that what ur saying???
http://www.topracingusa.com/setup.htm
If you are running on carpet use the Snowbirds setup.
Also, try raising your front cambner link to 2mm or 2.5mm. I'v personally had it as high as 3mm.
#1524
Check out George's CFP car I think it's ready to go.
#1525
canadianmeyhem, TOP Racing USA website: www.topracingusa.com and the email addy is [email protected]
#1526
yes. remove the rear.
put your shocks at the rear moore to the insede and on the suspention mount in the middle
on the rear blocks from the tiers 1 or 2mm spacers.
The plastick motor mount gifs more flex but it makes the car slower.
put the role center in the front a litle bit up.
change your steering on your transmitter.
make it a litle bit slower.
than you get also a more stable rear.
#1527
I have both the standard plastic motor pod base and the aluminum motor pod base... this is the bottom part of the motor pod that is screwed to the chassis for anyone's information...
Which should I use ? Is the additional flex from the plastic one really has an additional advantage or is the aluminum one better?
#1528
Tpg, you should give our Reedy Race setup a try:
#1529
looks like josh had a nice weekend with the new car, hope it is as equally as good on asphalt for the outdoor season
#1530
A few of the Mod drivers down here are running it quite often.
Switch between the two and see how you like it.
There is also an optional 2-piece flex top deck available now that gives a similar feel.
Cheers
Robbie
