Old 02-14-2006, 07:46 PM   #1
Default brushless motor... would you recomend?
would you guys recomend a novak velocity 5.5 for a noob like me? do they need alot of caring for? please let me know what you think and feel free to ask questions back
the #1 noob is offline   Reply With Quote
Old 02-14-2006, 07:53 PM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
Besides cleaning the bearings once every two months there is no maintence. If your running on a small-medium size track you should easily have more than enough power. If your a new racer it will probably be to much anyways though, even on a big track.
WheelNut is offline   Reply With Quote
Old 02-14-2006, 08:03 PM   #3
The Velocity 5.5 is a good choice for you. Dont have to worry about cutting comms, changing brushes, just plug and play. If you feel the 5.5 is to powerful for you in the start, drop down to 4 cells rather than running 6 cells. I can say my 6.5 set up with 4 cells in a 1/10 scale touring car is equal on power with a 19T motor.
vadn1 is offline   Reply With Quote
Old 02-14-2006, 09:22 PM   #4
The_Stig's Avatar
Easy maintenance, fast, fun, practically plug-and-play, how can you go wrong?
The_Stig is offline   Reply With Quote
Old 02-15-2006, 05:18 AM   #5
cool, thanks guys
Old 02-15-2006, 06:24 AM   #6
Hiwatari's Avatar
Send a message via Yahoo to Hiwatari
just wondering....the ss5800
s far s i'm concerned...it is censored based BL system
so...throttle response...will it b the same like when using brushed mod motor?
what i mean here is the throttle sensitivity
was thinking of getting into mod motor but was told about the hi-maintainance a mod motor needs compare to stocker
so if throttle response is just the same...might s well use it for practice n use the mod motor on race day only...economic should i say
Hiwatari is offline   Reply With Quote
Old 02-15-2006, 07:55 AM   #7
vtl1180ny's Avatar
R/C Tech Charter Subscriber
The only difference you are going to notice between a brushless and brushed is that the brushless has no drag break. You can always dial it in on your transmitter if you need some.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 02-15-2006, 03:13 PM   #8
AngryAsian's Avatar
That and a brushless feels slightly different to the brushed motors. I'm not talking about the sensitivity and i've NEVER felt any cogging from a BL motor(I've only run the Novak ss5800 + GTB 5.5R).
But.. the BL motors are very smooth. Smoother than a brushed motor, and the throttle is more linear. There's no real powerband to speak of, like you get with a low turn mod.
But i agree... fantastic choice!
However, i'm not sure about practicing with a BL and racing with a brushed motor. The new ss5800 does have drag brake but ultimately it does feel different. You'll notice the car feels different on turn in, as there are differing levels of forward weight transfer. The brakes on the regular motor will also be stronger...
Then again, lots of people practice on their backup equipment and race on their good stuff! (I disagree... i figure you might as well get used to the car in race trim with more power etc. etc.. than get used to two!!)
AngryAsian is offline   Reply With Quote
Recomend A Battery For Me not home Electric Off-Road 10 03-03-2008 11:23 AM
What mAh Lipo do you have/recomend mpb47553 Rookie Zone 4 01-29-2008 07:18 AM
Recomend a charger for me RBMike Electric Off-Road 24 10-08-2007 01:49 PM
Recomend me a Cheap but good Limitless ESC D4nny06 Electric Off-Road 8 06-14-2007 06:59 PM
Recomend Radio Control System? dmlk Rookie Zone 31 10-11-2003 01:18 PM
SEO by vBSEO 3.5.0
