Old 02-14-2006, 12:34 PM   #1
lookinco's Avatar
Default Getting the most from a race battery pack
So what's the best way to get the most power out from a race battery pack? Yes I have search before, and i read many threads. However I got so many different answers that I do not know which one is right.
Is it better to have it finished charging right before the race, pop in the car and start racing?
Or is it better to charge the battery before the race, then peak it again 5~10min before the race?
Will the battery perform better when it's warm or is it better when it's cold?
I am running the IB3800s right now.
This is what I usually do to maintain them:
1.Finish race
2.discharge battery with 030 discharger until light goes out
3.discharge battery with Team Lighting discharger until 0.90v per cell
4.store battery in box until next use
Then when I need to run again:
1.Take it out of the box and set it on the Team lighting discharger until 0.90v per cell
2.Charge the battery with the Duratrax Intellipeak charger. 4 step charge 4a > 6.5a > 4a > 6a battery usually cut off at delta-peak with around 4200~4300mah and 110f~120f temp
3.When 10min before the race, I charge the battery until it peaks again
4.pop in car and race
Is there anything I am not doing right? Is there a different setting for the charger in charging mode and peaking mode?
lookinco is offline   Reply With Quote
Old 02-14-2006, 01:12 PM   #2
Send a message via AIM to rcguy2477
The ideal is to have the car on the track right after the pack peaks as this will provide most power. Even if you repeak it, it still will not get up to the temperature it was when it peaked.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 02-14-2006, 02:26 PM   #3
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
batteries should generally be warm when they go out on the track. Motors should be as cool as possible. This combination will lead to a fast car. Generally, you want to charge at a "linear" charge mode....so like 5 amps or watever for the duration of the charge, don't do the step thing if you can aviod it (imop). Then when they call you up to prestage......."get your transponder" have the battery IN the car and strapped down and the charger wire like running under the body and have the thing set to re-peak. I like to re-peak at a 1amp higher than normal charge. so, I re-peak at 6 amps. This way the battery warms up a little quicker and has a tad more voltage when it hits the track. SO if timed correctly, it should tick off right as the last race is finishing and you have to go up.
Chris Woods
TQ Racing Wire
mafiaracers is offline   Reply With Quote
Battery pack teeforb Nitro Off-Road 3 11-19-2007 07:15 AM
IB4200 WC Race Packs, IB3800 Race Pack BSchorr R/C Items: For Sale/Trade 3 03-19-2007 02:47 PM
Charging 3pk battery pack (8 cell 2400mah Venom NIMH pack) mcgmark Electric On-Road 2 11-06-2006 07:57 AM
JR R-1 800mAh battery pack, charger cord [Tx & Rx pack], (8) 700mAh Nicads + cradle Tom G R/C Items: For Sale/Trade 2 08-17-2004 02:46 AM
Battery Pack doctorj Singapore R/C Racers 13 09-06-2002 06:29 AM
SEO by vBSEO 3.5.0
