Xray Fk'04 Asphalt Gearing ?? >
Old 02-14-2006, 10:16 AM
Ephidelt490's Avatar
Trader Rating: 17 (100%+)
Default Xray Fk'04 Asphalt Gearing ??
What's the best gearing for a short, outdoor asphalt track for an FK'04 with a 19T Epic motor? Thanks guys!
-Adam
Ephidelt490 is offline
Old 02-14-2006, 10:58 AM
Sorry if this is a dumb question? I'm new to on-road
-Adam
Old 02-14-2006, 12:06 PM
xrayaustin's Avatar
Trader Rating: 12 (93%+)
probabaly around a 7.20 final gear ratio
xrayaustin is offline
Old 02-14-2006, 12:13 PM
jw92656's Avatar
Smile
I run "stock" on a short track, and am geared at 7.3. For 19t I would maybe start with a 6.3 as a reference point. On your track take the longest straight, and cut it into 1/3. At the 2/3 mark you want the car to be topped out. Plug in a transponder, and if your track has it's lap timer on. Go up, or down one pinion gear, and look at your lap times. This will reflect which gear is giving you the quickest lap times. Hope that helped a little?
jw92656 is offline
