Robitronic Avid Touring Car
#661
Ciao Jeff,
i agree with you except for the lipo older, i mean using the lipo older you are obligated to fix the lipo also with reinforced tape crossing the chassis on the bottom, and honestly i don't like such method, i would like somethings like top that is using a velcro strap, i home made something like that, and i posted also some pics, but if supplyed from mssrs robitronic it will be much better.
ciao
Max
ciao
Max
#662
here is a pic of my shock showing where the hole is drilled for those who asked.
also i dont agree with the velcro thing im not a fan of velcro. i actually like using tape as a battery strap can produce chassis tweak and tape holds the pack down nicely and still lets the chassis flex. and the robitronic lipo holders are trick looking and i will be picking up mine shortlyat the moment i have been running ones i made quickly at work for the time being.
#663
Awesome picture Jeff, that helps out alot. Does the hole let the bladder flex more under compression??? Is that why it is drilled there??? Looks like you have some trick lipo holders on your car!!!!
#664
What are the advantages of the 0 angle driveshafts, has anybody run them yet????
#665
This is what I was told the 0 angle driveshafts. Have a shorter bone and a longer axle . The stock axles when you turn the wheels left and right the bone moves forward and. Backwards and causes the bone to rub against the wheel axle . The new ones keep this from happening and should remove chatter while turning . Hence 0 angle as the name . I should. Have mine by Monday. But they will improve performance for sure.
#666
Whats a good shock oil weight to start out with?? Also does the car only come with the 3 hole pistons?? Thanks for the help
#668
Can somebody post there setup for a rubber tire asphalt track???
#669
Car was great this weekend although I was not able to come away with a win I got 2nd in 17.5 stock with some good competition all weekend I was 0.2 off fastest lap in main. I am very happy with the way this car ran. Track was high grip, very hot temp 146* on track with 120ft back stretch.
Set up: All same as out of the box except for the following.
Front:
5.5mm ride hieght
3mm droop
550 cst sweep racing shock oil
hpi silver springs
hole drilled in shock cap
Ackerman center holes
6 screws on front top deck 2 of which not tightend that hold steering linkage
3.5mm droop
.5% toe out
1.5 camber
no sway bars
Rear:
5.5mm ride hieght
2.5mm droop
550cst sweep racing shock oil
hpi blue springs
hole drilled in shock caps
2 screws on back part of top deck
2 screws on top deck in front of spur gear
3% toe
2 camber
no sway bars
Front:
5.5mm ride hieght
3mm droop
hpi silver springs
3.5mm droop
.5% toe out
1.5 camber
no sway bars
Rear:
5.5mm ride hieght
2.5mm droop
hpi blue springs
3% toe
2 camber
no sway bars
#672
springs i would suggest buying 2 pairs of hpi silvers # 6543 and a pair of hpi blues # 6542 blues are softer so i would start with silver all the way around then if you need a little more rear grip try the blues.
#675
for the steering i use .1 and .2mm shims sold by tamiya on the post and hot bodies sells smaller diameter shims in .1,.2,.3mm which are what i use for the steering rack and to reduce suspension slop in areas.
