Old 02-07-2006, 02:39 PM   #1
Default which Turn motor for Modified?
Hi, I raced from a nitro background and have borrowed friends stock motors and found it a bit too slow.
I want to jump straight into mod racing.
I am looking at getting a teamBrood Pro v2.
my noobie question is why wouldnt everyone in mod just get the 6turn vs a 14turn?
less turn = faster?
also whats the difference between 12x1 and 12x2, what does it do?
noobie is offline   Reply With Quote
Old 02-07-2006, 03:06 PM   #2
xlgraphicspro's Avatar
It's all about what you can handle. If everyone could handle a 6x1 then this thread wouldn't be here. but more than likely you'll waste more time spinning your tires, ultimately going slower than you think. Now if you put in a 12x1 you might be able to handle the speed, your lap times will be faster. after you get a handle on lower winds, you could eventually move up, but some times the size of the track determines the type you'd use.
As for 12x1 Vs. a 12x2 or 12x3, the more strands, the smoother the power band. a single wind will be alot more punchy, a double or triple will be smoother
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 02-07-2006, 03:06 PM   #3
ford_racing's Avatar
Send a message via MSN to ford_racing
Firstly I'd try out a mild mod basically someting over about 10 turns to start off with and se how you go
Less turns does equal faster
12x2 means that there are 2 wires which get wrapped around each pole 12 times
12x1 is only one wire on each pole but still gets wrapped around 12 times
the higher the second number the more gradual the rpm increase
I was once told that a x1 was like a light switch and each extra one is less like one
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 02-07-2006, 03:14 PM   #4
T. Thomas's Avatar
The reason everyone does not get a 6 turn instead of a 10 or 12 turn is because the wear they create while running, and many people can not control these motors and be fast with them. Yes lower turns means faster mtoor, but it also means that your batteries will drain faster along with you will have less time to react for turns. If you are new to MOd I would suggest starting with a 10 turn, they will still require maintenance often(every 3 runs or so) but they will still last longer than a 6 turn.
The difference between a single(ie 12X1) and double(ie 12X2), is the number of wires used to make a turn(a turn is the number of times the wire/s are wrapped around each armature pole). THe lower the turn, the more RPM they hasve and more HP they have, with the down side of increased wear. The number of wires used to wrap each pole causes the torque to be moved around in the RPM range, lower the number (x1) will move the torque towards the lower portion of the RPM range and help increase the feel of accelerating faster. While increaing this number (x4) will move the torque curve closer to the upper limits of the RPM range of the motor, this will make the motor feel as if it is smoother with less acceleration out of a corner. For motors that have insane RPM(like a 6 turn), due to the turns being so low, they do not seem to have as much torque as a 12 turn does, that is why people use a x1 wind to get that initial acceleration out of corners back.
T. Thomas is offline   Reply With Quote
Old 02-07-2006, 03:29 PM   #5
thanks alot guys that helps alot. i'll prob start out with a 12x1 as we have pretty small/short tracks here
i was looking for warp4 2 turn motor. instead i bought a ALIGN 430L motor rasserie Singapore R/C Racers 8 10-24-2008 10:14 PM
New in package EPIC 19-turn modified motor C.Capelo R/C Items: For Sale/Trade 2 08-11-2007 02:25 PM
Why do Factory Modified guys runs 19-turn dawgmeat Electric On-Road 57 03-15-2007 06:56 AM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 10:03 PM
Trinity Chameleon 19 Turn Spec Modified Joel Lagace Electric On-Road 14 09-26-2002 05:03 PM
SEO by vBSEO 3.5.0
