Tamiya Tire choice?? >
Old 11-26-2002, 07:54 AM
Trader Rating: 24 (100%+)
Need some help guy's ! Getting serious about running the Tamiya challenge series but I have only run aftermarket tires,specifically Take Off cs-27. Can you tell me if the Tamiya tires are similar in performance and which ones to use for asphalt tracks. I'm in florida so track temps. are usually pretty high. I'll be running a tl01, tb evo 2 and possibly a ta04. Tire and insert combos would help also ? Thanks
Evoracer is offline
Old 11-26-2002, 09:30 AM
newracer's Avatar
You will want the B or B2 compound tires. Echo medium inserts work well or a firm for really hot temps. I have run in the TCS races and have some sedan tires around if you would be interested in buying them, some are brand new. I'll make you a good deal on them.
[email protected]
newracer is offline
Old 11-26-2002, 04:00 PM
ijnek's Avatar
hot temp?...
run type B2...tat's wat we use here...
the type B2 will b more consistent compare 2 type B...
ijnek is offline
