Like Tree4Likes
Old 11-03-2017, 07:03 AM   #1
mick8488's Avatar
Default FDR for touring mod
Hi gents,
I just bought an Orion 4.5t and am trying to adjust it for the optimal gear ratio. At the moment itís sitting at about 5.7 FDR but I was thinking of dropping it to 4.0 FDR via a 72t spur and 36t pinion as I need more speed. I run 48 pitch. Itís being run in blinky mode right now.
Can anyone advise on whether this will be a safe ratio to use with my motor and esc?
mick8488 is offline   Reply With Quote
Old 11-03-2017, 07:39 AM   #2
silden's Avatar
We run a FDR of 7.6 with a 4.5 and 7.4 with a 5.0 in blinky mode.
West Coast R/C Works
West Coast R/C Works Shapeways Store
LRP America
Ulti Tires
silden is offline   Reply With Quote
Old 11-03-2017, 07:50 AM   #3
Skiddins's Avatar
Originally Posted by mick8488 View Post
Hi gents,
What size track?
You're going to wrong way with gear ratio's, you want 7.1-8.0 even if running a mod motor in blinky mode.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-03-2017, 09:07 AM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
Here this should give you a little guideline adjust according to your track
Set likes this.
Old 11-03-2017, 04:07 PM   #5
No 2.5t or 3.5t boosted gearing ??? I guess they would be too fast ...lol.... I guess 8.8fdr to 10.2fdr would do just fine....
bertrandsv87 is online now   Reply With Quote
Old 11-03-2017, 04:11 PM   #6
Skiddins's Avatar
Top TC drivers don't run 3.5's, they boost 4.5 and 5.0's (or blinky on smaller tracks)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-03-2017, 04:12 PM   #7
Lead, never follow!!!.... LoL... Lots of power left to play with....
Old 11-03-2017, 04:22 PM   #8
Skiddins's Avatar
If a multitude of world champions don't need it, no one else does.
Just means you have a car that's more of a handful in the in field.
gigaplex likes this.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-03-2017, 04:34 PM   #9
World Champions are perfect drivers, unlike most of us... We need a little advantage sometimes down the straight to make up for our imperfections: it is always possible to dial back the throttle to make things manageable without having to purchase a weaker motor... Everyone is entitled to their opinions, but showing up with less power is not something I would recommend in Mod racing or any other type of racing...Happy Racing....
Old 11-03-2017, 06:16 PM   #10
gigaplex's Avatar
The amount you gain on the straight won't make up for what you'll lose on the infield when the overpowered motor makes the car harder to drive. Others have tried hotter motors and switch back when they find their lap times are better with the more mild motors. Plus you can always just boost and turbo to get the straight line speed anyway.
gigaplex is offline   Reply With Quote
Old 11-03-2017, 07:31 PM   #11
mick8488's Avatar
What size track?
It's a small track, front main straight with largely tight and twisty corners. Why would I increase my FDR? Wouldn't I lose out on speed?
My aim to get to an optimal FDR without boost as I don't think I need it for club racing.
NOVAROSSI WORLD s.r.l.: RACE ONE OR CHASE ONE
Old 11-03-2017, 08:08 PM   #12
Set
that little chart is surprisingly identical to my current settings
Set is offline   Reply With Quote
Old 11-03-2017, 08:28 PM   #13
gigaplex's Avatar
If it's a small track that's mainly tight and twisty corners, gearing for straight line speed will only slow you down.
Why would you want to avoid running boost? Conservative boost settings actually makes the motor run more efficiently than using static timing.
Here's an in depth article that talks about timing theory, and there are links to other articles covering how it applies to both blinky and boost
https://pphaneuf.github.io/rccars/ar...timing-theory/
No9 likes this.
Old 11-03-2017, 08:57 PM   #14
mick8488's Avatar
Thanks for the gigaplex, I'll be reading carefully over that article.
I guess I want to do one thing at a time. So I'll get my FDR right than look at boost. Why is the FDR higher for mod than stock?
Also, my mod motor came preset without about 30 degrees timing on the can. I wound that back to start off with only about 5 degrees but what do mod drivers normally do with can timing and what is the reasoning behind it?
Old 11-03-2017, 09:01 PM   #15
No9
No9's Avatar
Because decreasing your fdr means your actually slowing down your car.
It is similar to driving a race car around a track in 6th gear,the motor can't work to it's full potential.
Set your fdr to around 7.6 and watch what happens you may even find it's to quick,then drop the fdr down to 7.2 which will tame it down.
Antimullet likes this.
Schumacher Mi5evo/Ko Ex1v2/LRP/R1 wurks
Supported by MRJ RACING.COM.AU
No9 is offline   Reply With Quote
YOKOMO Touring Car BD-7 RC MARKET Electric On-Road 7502 09-03-2017 10:26 AM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
UK Race Talk TryHard Racing Forum 9876 12-05-2010 11:46 AM
