wtcc's FF project
#242
The CAD work is nearly finished.
I completed the most important parts, added electronic placeholders and the active toe holes. The front got shorter. I could move the servo 6.5mm closer to the differential. The bumper plates followed. The cable tunnel got a fitting form also. The anti-roll-bars were relocated and the mounts were drawn. In the rear I could use the mounts of the KRv2.5 without any change... nice The shocktower got a new design also. It came down and got thicker. The car was a great fun to design up to now
Here some CAD pictures for you to imagine what it will be soon:
#243
Looks promising to me. What is the wall thickness of the cable tunnel? In case the lever for the rear shocks are custom made I would add a stiffening rib between the two arms.
Regards,
Andy
Regards,
Andy
#246
I have thought of this too. But since he (wtcc) had done an earlier set up with the same motor position before, he probably has an idea on how to counter/correct that under-steer with this new design.
#248
Deck thickness?
Hi wtcc. Love your projects. I am currently working on a 4 gear transmission for my FF03, inspired by the Kentech blogs. I want to try and make the best front motor frontie i can! Anyway, as a next step after i test my transmission i have been thinking aboit a carbon chassis. Seeing your project got me thinking. What thickness carbon plate will you use? The TRF420 usibg 2.15 lower deck and 2mm top? I can get fibrelyte to cut out my designs quite easily, but they only have 2.5 or 2mm thickness options. Been thinking about 2mm lower deck due to the light weight of the rear end of the frontie design, and no motor torque to deal with. Any thoughts? What thickness are you using for yours?
#250
I haven't posted enough here to be allowed to post pictures yet, but this is my post from my Tamiyaclub build thread with a few pictures and explanation
https://www.tamiyaclub.com/forum/ind...comment=788701
#252
https://kentech.wordpress.com/2015/0...-car-20739548/
#253
Time for a designfreeze!
I did a lot of detail changes in the front area regarding servo position and gearbox geometry. The latter was refined a lot. In comparison to the previous chassis, the car got 7mm shorter in front.
Today I prepared the data for the manufacturing. Compared to the KR v2.5 the number of parts is very small: 10 to 54
Yesterday evening I disassembled the MF chassis and cleaned every part. It is a car without skeleton
I couldn't wait and started building the suspension. I will also do the turnbuckles soon.
Now it is time to wait. Shapeways is working and I need to wait for an offer for the carbon parts...
