Old 03-26-2002, 07:37 PM   #1441
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Good to hear you got it. Regarding the scuff marks on the bottom, if you really wanted to you could probably get it polished. A guy here spilled CA glue on his 414M chassis and filed it off and re-polished it at a machine shop.
Speedo
Speedo is offline   Reply With Quote
Old 03-27-2002, 06:43 PM   #1442
Simon K's Avatar
Wink
I've just replaced all the balljoints and ballstuds in the steering of my SP.
When it came time to do the long shank, silver ballstuds from the servo and bellcrank, I noticed there was a lot of slop in these(From new) and not in the black shorter ballstuds.
Pretty much all the slop in the steering was from these two silver ballstuds, so I replaced one with the shorter black type and will figure something out for the other on the bellcrank as it needs to be a little taller.
Simon K is offline   Reply With Quote
Old 03-27-2002, 07:22 PM   #1443
Moderator
Speedo's Avatar
Simon, I noticed the same thing. I used Losi ballstuds, shimmed them to the right height and Losi ballcups. They seem to be more durable, and having had them on there for a year, there is still no slop in that part of the suspension.
Speedo
Old 03-28-2002, 01:22 PM   #1444
Da4head's Avatar
What are you guys using for the front carrier ball stud in the Tosilini setup. I tried a regular but longer one but the carrier slops around and wears out the steering block hole.
Da4head is offline   Reply With Quote
Old 03-28-2002, 04:20 PM   #1445
Moderator
Speedo's Avatar
I used a tamiya ballstud and cup, you have to drill the top hole in the castor block out a little bit, but it works.
Unfortunately, I think you can only get the tamiya ones in a 15 dollar steering set. I got mine from a friend who runs a tamiya and had some sitting around.
Speedo
Old 03-28-2002, 06:36 PM   #1446
mo
mo's Avatar
Yokomo has the kingping ballstud setup. I believe the part number is ZR-007.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 03-28-2002, 06:54 PM   #1447
Moderator
Speedo's Avatar
Yeah I know, but as soon as Tosolini started doing that, their stock was gone very fast I tried to get the yoke ones but couldn't, so the tamiya ones work.
Speedo
Old 03-30-2002, 03:02 AM   #1448
Send a message via AIM to ZER01
Thumbs up
Onroad Electric and Nitro "State Championships" May 4th @ Small Cars Unlimited.
ZER01 is offline   Reply With Quote
Old 03-31-2002, 10:33 AM   #1449
MiSFitSLvR's Avatar
Send a message via AIM to MiSFitSLvR
i will have a yok again in a few days. i used to have one but i traded it away but now i am getting a new one. it is worlds edition. i was thinking of getting the penguin edition chassis for it. is that chassis okay? lmk what i should start buying for it other than springs and tires and stuff. it has both oneways. i will be racing at Speed World Raceway if any of you guys know any good setups for the track.
later
MiSFitSLvR is offline   Reply With Quote
Old 03-31-2002, 11:36 AM   #1450
Moderator
Speedo's Avatar
I would buy the special conversion for it. It is cheaper and you get more stuff.
Speedo
Old 03-31-2002, 01:35 PM   #1451
MiSFitSLvR's Avatar
yeah i have been looking at that. at speed world they are only 70.00 i think that will be what i buy fist. is there anything else i should buy? lmk
Old 03-31-2002, 01:42 PM   #1452
Moderator
Speedo's Avatar
You'll be pretty much set with a worlds converted to special, you should end up with everything the full blown special kit has.
The only things I can think of are spare parts (arms, rear bulkhead etc.) if you're LHS doesn't stock them, and some tuning options such as 3 degree castor blocks, and the yokomo kingpins with ballstuds on them.
Good Luck,
Speedo
Old 03-31-2002, 02:06 PM   #1453
TK
MisFit You definately choose the right track for set up info from drivers. We are lucky at SWR that we have both Jason Moberly and Alex Seimantel that both run for Yokomo. Both of them are extremly friendly about set up advice and will help you out on it. BTW when you start racing look for a teenager that everyone talks about kitties about and runs a silver and pink body....That would be me and can help you out as much I can. Also try www.mo-net.ws I belive. Its mo website and he has some good set ups to try. Anyways see ya out at SWR
TK
TK is offline   Reply With Quote
Old 03-31-2002, 02:32 PM   #1454
MiSFitSLvR's Avatar
i am a teenager too. how old are you i am 14. i cant wait to race at swr. i knew they had factory drivers. i know if i was a factory driver i would race their. it is a really nice track! i am going to live like 10 minutes away from the track when i move up there. well thanks guys
Kurt
Old 03-31-2002, 03:38 PM   #1455
There's been quite a bit of talk about the Kingpin Ballstud conversion but I have not found an explanation as to what exactly it does to the handling of the car.
Also what is the conversion that can be done to the rear hubs and what effect does this have on handling.
Thanks for any feed back.
Yorkie
Yorkie is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
SEO by vBSEO 3.5.0
